Sticking brake pedal - JeepForum.com
post #1 of 4 Old 11-07-2005, 12:27 PM Thread Starter
PatrickMcD
Hey guys
Got a question about an issue i've had with the brakes on the jeep since I bought it in June. Since then I've replaced the rear brakes and one rear cylinder, but the same issue. The brake pedal in the truck sticks. It feels okay stoping usually, but the pedal generally tends to stay down, to the point of almost holding the truck in place while idling in drive. When driving, I have to push the brake pedal back up with my foot to keep it going. I'm thinking it's the master cylinder, but i wanna be sure before I cough up $55 for a new one.
If it does turn out to be the MC, is there any trick to installing it (never installed a MC on an ABS-equipped vehicle)
Thanks in advance
-PM
PatrickMcD is offline
post #2 of 4 Old 11-07-2005, 01:05 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Did you bleed the system after the wheel cylinder replacement? Try to bleed the master cylinder before buying a new one.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 4 Old 11-07-2005, 01:24 PM Thread Starter
PatrickMcD
i did a quick bleed of the system when I replaced it. Should I go ahead and do the whole truck?
post #4 of 4 Old 11-07-2005, 02:39 PM
Matt Gertsch
www.lp.org
That's where I would start. Usually a weak feeling pedal is from air in the brake lines. Really bad pedal feel can come from air in the master cylinder. Any shop manual will lay out MC bleeding for you. I think you'll need to bleed the ABS pump too if there is one.
brake pedal very soft after dual diaphragm brake booster upgrade 180XJ92 XJ Cherokee Technical Forum 1 09-14-2009 01:06 AM
rear brake problem what is sticking out of it camxxxl XJ Cherokee Technical Forum 2 09-08-2009 06:51 PM
Brake lights work...but NOT with the brake pedal (???) aallppiinnee XJ Cherokee Technical Forum 4 03-08-2009 06:26 PM
brake is sticking toates89 XJ Cherokee Technical Forum 8 03-11-2008 01:40 PM
Hissing Brake Pedal: Brake Vacuum Pump Sykes XJ Cherokee Technical Forum 3 06-24-2007 07:44 PM
