Stereo Remote Wire - JeepForum.com
post #1 of 12 Old 04-16-2006, 12:30 PM Thread Starter
mellow
Stereo Remote Wire
What gauge of wire would you think would be absolute necessary for this? My stereo remote wire doesn't work so what I'm doing is running a wire from the positive on my amp to the remote port on my amp, and just putting a toggle switch on it. Wouldn't 14 gauge wire and a 10 amp toggle switch be enough?
1992 Cherokee Limited 4x4 H.O.
NP242 & AW4 | 31"x10.5" On Jeep™ Honeycombs
JVC Deck
Jensen BP212 (2x12" 1200W Plexi Bandpass w/ LED's)
Cherrybomber GLASSPACK.
mellow is offline
post #2 of 12 Old 04-16-2006, 12:37 PM
cjwalkeriii
You dont even need that thick of wire. 18 gauge with .5 amps is plenty... You can also just run a wire of your ignition so when the key is on so is the amp
cjwalkeriii is offline
post #3 of 12 Old 04-16-2006, 06:08 PM Thread Starter
mellow
Even my stereo isn't like that :P
Right now I can turn my stereo on without my keys. Also, I want to be able to have my amp power 'on-demand' so I have the option of turning it off when I'm driving if need be. The speakers in my signature are no longer in it. Now I'm just running a single Jensen box with 2 12" subs rated at 1200W.
Yesterday my Jeep caught fire... I had the remote wire with a switch idea and somehow the switch fried and all of the wire got toasted. I'm not sure if it was the switch or the mixture of wire I was using. All day today I had it on with 14 gauge wire and it never overhated, so it must have been the cheap switch or the 18 gauge speaker wire I was using yesterday lol.
So I have a switch rated for 15 amps now, and I'm using 14 gauge wire throughout so hopefully it won't be a problem. Thanks for the input.
JVC Deck
mellow is offline
post #4 of 12 Old 04-16-2006, 06:27 PM
jeeper01
That sounds like an accident waiting to happen, thats why most radios have power buttons on them.
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
jeeper01 is offline
post #5 of 12 Old 04-17-2006, 12:45 PM
twisted_ed
twisted_ed's Avatar
DO NOT DO THIS. this will make ur amp on ALL the time, and will drain your battery, this happened to my Girlfriends car, dead every morning cause her amp would not turn off properly. run the remote wire to a toggle on the dash or to the ignition so it comes on only when the key is turned.
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
post #6 of 12 Old 04-17-2006, 04:42 PM Thread Starter
mellow
Incase you didn't read correctly, I said I'm going to use a switch and wire. I wouldn't hook it up and leave it - I'm not that stupid. I'm in the process of wiring a switch to the remote wire right now. Got the XJ in pieces, poor thing.
JVC Deck
mellow is offline
post #7 of 12 Old 04-18-2006, 06:48 AM
festerw
festerw's Avatar
If you can turn your stereo on without the keys it is wired wrong plain and simple. Use the switched 12V line for a remote to the amp.
Here's a link to wiring colors (you may have to join the site, but it's free and has all kinds of useful information.)
91 XJ Wire colors
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #8 of 12 Old 04-18-2006, 09:43 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Why would you want to wire any of the stereo components so that it will be able to be turned on without the keys? Thats just leading to dead batteries. I had my YJ radio wired like that, drained my battery. I didnt know if it was really turned off or not because the face plate was faulty. Everything should be on a switched 12v. If you put in another manual switch after that, thats fine.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #9 of 12 Old 04-18-2006, 09:55 AM
pnpxtreme
Why wouldnt you just run a wire with an inline fuse to your fuse box on a fuse that was only on when the car was on?
pnpxtreme is offline
post #10 of 12 Old 04-18-2006, 10:06 AM
XJ-NoDough
XJ-NoDough's Avatar
Well that would be too clean and easy... I wouldn't tap into the amp power wire with a switch, there is too much current there, fire and melting wire waiting to happen. Really I would think about a new head unit. The one you've got and all the band-aid solutions are just gonna be headaches, I've been there. But if a new unit is too far off I'd do the fuse block idea.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #11 of 12 Old 04-19-2006, 10:43 AM
98RedLtd
Your harness caught fire!!!! I don't think the above can be automatically assumed.
98 XJ Limited
Daily Driver
All Stock
178,000 miles
"I once saw protestors holding paper signs on wooden sticks protesting timber cutting and I though...If they didn't cut the timber...How would they make their signs????"
98RedLtd is offline
post #12 of 12 Old 04-19-2006, 02:04 PM
Blake
Redefining body roll
Blake's Avatar
Wait... you're putting a switch on the power wire or the remote wire? The thread says remote, but it sounds like you're talking about the power wire. No way you'd smoke a switch on the remote wire.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
Remote Wire For CD Player backwoodz XJ Cherokee Technical Forum 8 01-31-2008 06:36 PM
Need to access a lead wire for stereo amp-where can I find an ignition only hot wire? Mud Machine XJ Cherokee Technical Forum 8 08-18-2006 11:45 AM
99 stereo wire colors? Xjcrusader XJ Cherokee Technical Forum 4 08-11-2004 03:38 PM
help with stereo wire harness jukesjoker XJ Cherokee Technical Forum 2 06-02-2004 06:32 PM
Where does the PCI-bus wire go from the stereo headunit? JTS97Z28 XJ Cherokee Technical Forum 1 04-07-2004 12:30 PM
