Stereo keeps power, but sound comes out randomly - JeepForum.com
post #1 of 13 Old 04-01-2013, 02:46 PM Thread Starter
grandezj
I have owned my XJ for a few months now and the stereo (stock P04858556AD, 4 speakers) or wiring has always not worked correctly, at first I thought it was one of the door speakers that the wire had broken to and it was shorting, but after I finally got time to fix the door wire I thought it would work properly, but i'm still in the same place with the stereo not working, I also thought this problem had to do with movement of something when I drive, because sometimes the sound comes back when i'm braking or steering, but when I was sitting here not moving or touching anything (with the ignition in accessory and it did it again with the ignition in on) the sound came back, then I started it and no more sound, every time the stereo loses power it seems to go quiet again, but sometimes it dosen't work for days, any idea what could cause this? The fuses are fine, and all the wiring seems to be ok superficially The stereo will occasionally stay working for a day or a few at a time, but then go back to being silent, I have no clue what makes it work intermittently, any help would be great
grandezj is offline
post #2 of 13 Old 04-01-2013, 03:34 PM
TheBoogieman
Disturbed Rubicon owner
TheBoogieman's Avatar
Sounds like it's time for a decent aftermarket stereo.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #3 of 13 Old 04-04-2013, 11:18 AM
JWELK
Which speakers are intermittent? Use the fader/front rear controls to isolate them. The door speakers are always subject to breakage. On my '99, the left door was the culprit. I also had intermittent lights in the door, window, and mirror backlights. Turned out to be bad ground, the wire pulled out of the lug. Never did find the lug, but replaced the lug and tied it into the speaker mounting hole, problem solved.
Do you have a meter, and know how to use it?
Regards,
Jim W
JWELK is offline
post #4 of 13 Old 04-05-2013, 06:56 PM Thread Starter
grandezj
Regards,
Jim W
All of the speakers go out, I have played with the fade and balance a lot when I'm stuck in traffic and got nada, and recently I quiet static out of all of the speakers, in addition to sound, every so often, which means that my wire patch works, and I used my multimeter to check if everything was good, and I got something, so I think that TheBoogieman might be right and my head unit is trashed somehow, because it has gotten progressively worse, gonna pull one out of the junkyard Monday (~$7 for a stock one with no tape or cd player) that will be the final test of all the wiring and will test my antenna (which is another thing that might be causing this) if that doesn't work, than I'm going to literally pull out every wire in this entire harness to find out what needs to be patched
grandezj is offline
post #5 of 13 Old 04-28-2013, 04:26 PM
pharunk
2010 KK Liberty
Any update here? I think I have the exact same issue.
In short: When radio is operating, it will intermittently "shut off". Better said, there is no sound, although you can still see the station it is on (or the time, depending on what is selected). So you know that the unit has power, but it is not working.
Here is my saga: I have a 97 Cherokee Sport. When I bought the vehicle it had an aftermarket (JVC) stereo in it that worked fine. about two years ago, it started cutting out when the I turned the volume up high. Turning it down seemed to fix it. Fast forward to a few months ago, and it started cutting out at all volumes. As time went on, it started happening more and more. I wondered if there was an issue with the grounding, but since it goes into that spinal column of a harness, it was impossible to trace the wire back. So, I ran a separate ground from the frame under the door directly to the ground wire on the radio. No change, so I determined the ground is fine and went back to original connection. I also checked the fuse and it is fine. One night, I noticed that when it was not working, I did see two dim lights on the unit, so that told me it was getting power.
Today, I saw a stock stereo from a 99 (I think) on craigslist for $15 so i called and bought it. The 20 year old kid that sold it to me said it worked fine and he took it out two weeks ago when he bought an aftermarket unit. I put it in my Cherokee and it immediately worked, but intermittently! Same issue as I was driving home: Worked fine for a while, then cuts out, either for a few seconds or longer, sometimes many minutes at a time. Again, when it is not "working", I can still see the time/station display.
An added twist: With the stock radio in there, when it started working again, it is stuck on the same volume (about 4 out of 10). No matter where I turn the dial, the volume is that same level. Also, none of the other adjustments work (bass, treble, balance, fade)
Being that I am having the same issue with two different radios, one stock and the other an aftermarket, I am led to believe there are issues in the "spinal cord" wiring harness that disappears into the dash.
For the record, this Cherokee has over 200k miles and getting along on the rust. Also having intermittent power window issues and the rear wiper is not working. Assume the rear wiper motor is gone, but not sure
With all the Cherokee Sport owners out there, I have got to believe that others have had this radio issue and SOMEBODY must have figured it out by now. Anyone?
pharunk is offline
post #6 of 13 Old 04-28-2013, 08:40 PM
sAe23
1995 XJ Cherokee
The OP needs a new stereo, and Pharunk needs to run new wires. It will be a PITA, but probably easier than finding the problems with the factory loom.
sAe23 is offline
post #7 of 13 Old 04-29-2013, 09:55 PM
pharunk
2010 KK Liberty
I was afraid of that answer
I was hoping for a quicker fix. In any case,
1. Has anyone replaced this wiring harness for the radio? What kind of effort is involved?
2. I can't locate any visuals showing where the wires go as they split up before and/or after the firewall. Anyone have visuals of this, or a resource that tells me where the wires end up on the other end?
3. I am guessing one set of wires is for speakers inside the vehicle and the other set goes under the hood?
Help, anyone?
pharunk is offline
post #8 of 13 Old 04-30-2013, 11:00 AM
sAe23
1995 XJ Cherokee
The radio (stock or aftermarket) will have:
Power; SWITCHED power; Clock power; Display dimmer feed; speaker feeds (left/right, front/rear, +-).
Aftermarket might also have power antenna and remote amp leads.
You should get a copy of the factory service manual as your 1997 is different than my 1995 so I can't be sure of color codes on the wires.
You might just have a bad power (switched) wire, so you might want to start by running a temp wire to see if that helps.
Unfortunately, working under the dash is a PITA...
sAe23 is offline
post #9 of 13 Old 05-01-2013, 09:28 PM
pharunk
2010 KK Liberty
Can I run a "jump" wire directly from the back of the radio right to the fuse panel to check it? Does the existing switched power wire touch anything else?
pharunk is offline
post #10 of 13 Old 05-02-2013, 03:01 AM
sAe23
1995 XJ Cherokee
It's what I would try... it *shouldn't* hurt anything else.
sAe23 is offline
post #11 of 13 Old 05-17-2013, 11:01 PM Thread Starter
grandezj
Sorry for the late reply, got the new stereo in and everything's been great since, thanks!!
grandezj is offline
post #12 of 13 Old 05-18-2013, 09:24 AM
pharunk
2010 KK Liberty
it doesn't appear that there are separate switched and clock wires. If i remove the fuse to the radio, the clock is not on. If there are separate wires, do they go to the same fuse?
pharunk is offline
post #13 of 13 Old 05-18-2013, 10:22 AM Thread Starter
grandezj
Everything goes to the accessory or radio fuse
grandezj is offline
