Quantcast Steps to follow when taking the head off. 4.0L - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Steps to follow when taking the head off. 4.0L
GR8TOPS Introduces the Exogate HD Tire CarrierIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 04-09-2009, 03:40 PM   #1
JeepXJ2001
First thing first I washed the engine.
The Haynes manual is missing steps.
It starts with setting up the engine to top dead center and secondly its jumps to removing valve cover, the intake and the exhaust manifold and skip to tell us how to take out the injectors and all that...
Could you please tell me the steps I need to follow in order to take out the head.
personal record head gasket installation complete in 9 hours.
My only true friend JeepForum.com... Thank you !
My Jeep Photos
JeepXJ2001 is offline   Reply With Quote
Old 04-09-2009, 04:28 PM   #2
JeepXJ2001
oh god I feel stupid.. Sorry for my stupid question...
My Jeep Photos
Old 04-09-2009, 04:43 PM   #3
danno627
i believe in the haynes manual if you go to the section for removing the manifolds it tells you how to do all that.
danno627 is offline   Reply With Quote
Old 04-09-2009, 06:08 PM   #4
JeepXJ2001
will do that sir.
thanks
My Jeep Photos
Old 04-09-2009, 06:16 PM   #5
justanotherjpr
x2 it should have you skip the appropriate section for each part
justanotherjpr is offline   Reply With Quote
Old 04-09-2009, 10:03 PM   #6
wolfepack215
1987 XJ Cherokee
The Haynes manual is missing steps?? You don't say?!! Not a fan of Haynes manuals for other than minor maintenance on the Jeep.
there are about (10) 13mm bolts on the top of the intake manifold. (4) hold down the fuel rail. also, on the front of the manifold there is a 13mm bolt that has a bracket that holds the vacuum harness to it, and also holds the fuel line in place. Remove your power steering pump and behind it there are two 14mm bolts that bolt into the manifold. also, at the back of the manifold is a bracket that retains the incoming fuel line. Im not sure with the late model Jeeps, the a/c bracket may be tied into the head as well. Since you are removing your head, check the freeze plugs, if they show signs of wear/corrosion, now is a good time to think about replacing them (with brass), the only one you cant get to is behind the block behind the bellhousing. Not sure how much this helps, but I hope I gave you some ideas...
wolfepack215 is offline   Reply With Quote
Old 04-09-2009, 10:14 PM   #7
justanotherjpr
I have a PDF of the FSM (Jeep's Factory Service Manual) for the 2000 Jeep XJ. It's 40MB. Shoot me a PM with an e-mail addy if you'd like it.
Edit: Also have complete parts lists, too.
Old 04-10-2009, 06:52 AM   #8
JeepXJ2001
Wow FSM that sounds super nice a dream come true... Thank you dude...
This is what I did yesterday. I took out the air intake and the throttle body, I separated the fuel line and took off the fuel rail and the injectors. I could not figure out how to take the wire harness off yet.
My Jeep Photos
Old 04-10-2009, 10:07 AM   #9
justanotherjpr
Just let me know where you want it sent to
Old 04-10-2009, 10:19 AM   #10
JeepXJ2001
I broke the plastic tube I think its the vacuum thingy that is on the valve cover, the closer one to the back. The one that connects to the intake manifold Damn
I wonder if it is expensive?
My Jeep Photos
Old 04-10-2009, 10:23 AM   #11
jjg214
it cost me 10 bucks at the dealership, i broke it when i changed my valve cover
jjg214 is offline   Reply With Quote
Old 04-10-2009, 10:28 AM   #12
justanotherjpr
Do you have a part #?
Old 04-10-2009, 11:38 AM   #13
JeepXJ2001
I got a FSM. This means I wont be asking as many questions. Thanks god...
My Jeep Photos
Old 04-10-2009, 04:31 PM   #14
JeepXJ2001
I am trying to remove the exhaust manifold and it took me more than one hour to take first bolt off. I am using a 15 mm 3/8 short socket. a few extentions. I am reaching the bolt from under the car. and thats the only way I can possibly reach that bolt.
I cant take the darn thing out? What should I do?? Should I just disconnect the exhaust and o2 sensor? and pull the whole thing out with the intake manifold??? I cant possibly think that I can torque this thing back
I am super frustrated after spending more 2 hours and a half under the car and only be able to take one bolt of.
Please help !!!
My Jeep Photos
Old 04-10-2009, 05:01 PM   #15
justanotherjpr
You can disconnect the exhaust downpipe and leave the intake/exhaust manifolds installed on the head and then seperate them after you move the head out of the way into a better spot. You can also remove the motor mounts and carefully lift the motor using a jack and a block of wood to get more clearance.
Glock Forum
