step by step a/f ratio - JeepForum.com
post #1 of 5 Old 05-15-2013, 06:56 PM Thread Starter
Cmense
Can someone find me a link for a step by step thorough diagnosis to fix bad air to fuel ratio?
Cmense is offline
post #2 of 5 Old 05-15-2013, 07:03 PM
chriskeenan
How do you know the AFR is bad?
Does the Jeep run? Good? Rough?
Fail emissions testing?
chriskeenan is offline
post #3 of 5 Old 05-15-2013, 07:10 PM Thread Starter
Cmense
It passed emissions because In pa they just check the gas cap/ exhaust for holes. I have thick black soot in my tail pipe, just today started burning oil. Or at least I just noticed it today. But I have an exhust leak on the y pipe and have bad 02 sensors. A vaccum leak on the manifold gasket. Lol a bunch of crap. The jeep doesnt run perfect but I know Im running very rich with the tailpipe scent and soot. After fixing all of what I just mentioned I planned in maximizing my air to fuel ratio because its outta wack now. Obviously everything I stated also affects it I know but just so I dont overlook something it would be nive to havea step by step
Cmense is offline
post #4 of 5 Old 05-15-2013, 07:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Fix that **** first. That's the issue. When you've got a headache do you go in for a CAT scan or take an aspirin?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #5 of 5 Old 05-15-2013, 07:20 PM
chriskeenan
Fix all the leaks first, then replace the O2 sensors if it still isn't running correct. AFR is all based of the O2 readings and the MAP sensor data.
Burning oil is a whole different issue. you're either looking at massive PCV blow by or the piston rings or possibly the valve stem seals are going.
