Steering Problem... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Steering Problem...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 04-25-2009, 11:40 AM   #1
missXJ
Steering Problem...
I've got a 2000 sport that makes a really loud knock when turning left, any ideas as to what it is?
it's louder when I'm at lower speeds like going through parking lots and what not. You can feel the knock in the steering but the whole front end doesn't bump or anything. It's mostly a loud sound that I'm afraid is ****in up shop more every time it happens
It's a Jeep thing, not even I understand...
missXJ is offline   Reply With Quote
Unread 04-25-2009, 12:40 PM   #2
thetank
go through the steering under the jeep. check the steering gear bolts, the bolt holding the pitman arm on, and the tie rods. you should also check the track bar bolt on the axle side to make sure thats tight. my jeep was making a poping noise when i turned, and it turned out to be two of the steering gear bolts were slightly loose. they only tightned like a 1/4 turn tighter, but the noise went away. hope this helps.
98 xj with rc 6.5 in lift, re hack an tap sye, homemade steering box plates, durango steering box, v8 zj tie rod, soft 8s, 37in mtrs. 4.88 gears, no slip in the rear, electrical problems ect..
thetank is offline   Reply With Quote
Unread 04-25-2009, 01:47 PM   #3
maddzz
1989 MJ Comanche
Mine was doing this too. For me, it was the trac bar at the frame end (the one that looks like a tierod end). Pull the cotter pin and tighten down the nut that is inside the bracket. If this solves the noise but it comes back in a few weeks you will either need to replace the trac bar or the bracket itself; the hole in the bracket wallows out letting the trac bar keep coming loose.
maddzz is offline   Reply With Quote
