Steering Knuckle/Brake Problem again!! - JeepForum.com
post #1 of 4 Old 03-30-2008, 01:20 PM Thread Starter
shaddady34
I replaced my passenger steering knuckle 5 months ago on my 2001 xj. The ledges where the pad rests on were getting worn grooves into them and thus the caliper was getting hung up. I replaced the entired knuckle pads and got a rebuilt caliper. Now 5 months later i start to hear squeaking from that area. What do you know but there is a little groove already starting to where on the ledge surface. Does anyone know how to avoid this problem from happening and an alternative to replacing the knuckle..... any suggestions wlould be appreciated!!
shaddady34 is offline
post #2 of 4 Old 03-30-2008, 02:17 PM
sprintagogo
get a welder
I used a grinder to clean back to clean metal then put a good blob of weld onto the effected area then ground it back down to the correct profile. I am not sure about the rights and wrongs of welding cast/forged? items but it worked for me and was cheaper and far easier than replacing knuckles.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #3 of 4 Old 04-11-2008, 08:03 PM Thread Starter
shaddady34
any other ideas why this is happening again after i replaced the knuckle and caliper??????
post #4 of 4 Old 04-11-2008, 08:28 PM
SilverXJ
grease the sliders on the knuckles and the bushings on the calipers. I found that the brake grease they sell in the little packages at the check out desk at places like Advanced Auto seem to work the best for the bushings and sliders.
SilverXJ is offline
Brake Problem, Need New Hub Assy or Bent Knuckle? natetuff XJ Cherokee Technical Forum 10 07-01-2009 07:41 AM
Brake rails on steering knuckle grooved. Redgord XJ Cherokee Technical Forum 4 05-03-2009 07:49 AM
steering knuckle fix silentneko XJ Cherokee Technical Forum 6 04-04-2009 06:26 AM
over knuckle steering ????? jeepin4u XJ Cherokee Technical Forum 2 03-22-2009 02:51 PM
Steering knuckle jeepsterwannabe XJ Cherokee Technical Forum 2 09-03-2005 07:40 AM
