Steering Issue!, steering wheel and tires wobbling - JeepForum.com
post #1 of 11 Old 07-26-2008, 05:15 PM Thread Starter
Swagger_Wagon
I'm kind of shaken up already as I just test drove my new 2001 XK sport. When I put it in 4hi and tried to make a complete turn (like a cul-de-sac, almost full lock) the wheels and my steering wheel started wobbling back and forth violently. I figured that was simply the front tires grabbing at pavement at low speeds. but then I put it back in 2WD and tried the same maneuver the wheels and steering started wobbling like crazy again. am I just over reacting or is this a serious problem? This is at low speeds mind you not the 40-50mph "death wobble"
Thanks!
P.J. O'Rourke
The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve. Okay, were a little crazy to have a Jeep for a daily driver. But if we go off our meds, we might wind up in a Prius
Swagger_Wagon is offline
post #2 of 11 Old 07-26-2008, 05:33 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You shouldn't be using 4hi on the pavement, you can easily break an axle. and for the wobbling you should check all your bushings. especially the trac bar bushings. also check that the tierod ends are tight with no play. the best method for this would be to lay under the front of the vehicle, and watch all the components as someone else turns the steering wheel back and forth. PLEASE BE CAREFUL AND DON'T LET YOUR SIX YEAR OLD SISTER RUN OVER YOU DURING THIS PROCESS. Be sure to let someone with some common sense help you.
xjfever is offline
post #3 of 11 Old 07-26-2008, 05:40 PM Thread Starter
Swagger_Wagon
alright the damn thing just ran 12 hours straight from chicago to ATL, everythings hot as hell, you can barely touch the hood, but the weird thing is my pops said there wasnt any of that movement yesterday before the trip. idk well see. maybe something rattled loose during the drive down.
P.J. O'Rourke
post #4 of 11 Old 07-26-2008, 08:50 PM
bdb12586
2005 WK
when you say wobbling is your steering wheel sort of jerking out of your hands when you make a sharp turn. I had a problem like this once it was the u joint in the front axle I also noticed that if I jacked the front tires off the ground, turned the steering wheel, then tried to spin the wheels by hand the wheel would try to striaghten out because of the u joint bind.
well something to consider anyway
bdb12586 is offline
post #5 of 11 Old 07-26-2008, 08:58 PM
maddzz
1989 MJ Comanche
Is your tire rubbing on the lower control arm?
maddzz is offline
post #6 of 11 Old 07-26-2008, 09:10 PM Thread Starter
Swagger_Wagon
ok thanks a lot for your help guys. Ill check out all of your suggestions tomorrow morning. If we are still stumped we just may take it to a jeep specialist around here and see if they have any clue. hopefully I can pinpoint the solution. and yes the steering wheel does jerk itself out of my hands as your described maybe it is that u joint.
thanks again!
P.J. O'Rourke
post #7 of 11 Old 07-27-2008, 12:58 AM
asknight
If the only thing you broke was a u-joint by running 4-hi on asphalt and attempting a full circle, consider yourself lucky.
Please review your owners manual.
asknight is offline
post #8 of 11 Old 07-27-2008, 09:28 AM Thread Starter
Swagger_Wagon
I have "reviewed" my owners manual. and thanks for picking such a discreet way in which to say good job jack***. but anyways, Ive been doing some research and looking under the car and am thinking that the issue may be the differential not going back into 2WD. just a thought.
P.J. O'Rourke
post #9 of 11 Old 07-27-2008, 09:45 AM
THISISWEIRD
Do you mean Transfer Case?
THISISWEIRD is offline
post #10 of 11 Old 07-27-2008, 09:51 AM Thread Starter
Swagger_Wagon
appreciate the help
P.J. O'Rourke
post #11 of 11 Old 07-27-2008, 12:17 PM
THISISWEIRD
I was trying to help, but from how I'm taking your tone in this last post and the one a few posts up, I could care less. Good luck.
Changed out steering box and now steering wheel won't lock... what did I do wrong? bizzo15 XJ Cherokee Technical Forum 2 11-12-2009 05:43 PM
Bad used steering box or another issue? steering wheel looseness PUNISHER_VETTE XJ Cherokee Technical Forum 4 11-01-2009 08:37 PM
What would cause your tires not to move when you turn your steering wheel? Magus2727 XJ Cherokee Technical Forum 15 10-01-2009 06:25 PM
Steering still a tad jerky low speed, power steering issue? Swagger_Wagon XJ Cherokee Technical Forum 7 05-15-2009 06:54 PM
loose steering + steering wheel shimmy Witt XJ Cherokee Technical Forum 1 07-28-2003 01:12 AM
