Steering feels weird after wheeling - JeepForum.com
post #1 of 5 Old 10-26-2010, 09:54 AM Thread Starter
GnarlyCharlie
1997 XJ Cherokee
Why does my steering feel like the Jeep is still in 4 wheel drive after a day of wheeling? Now on the road going around turns, the steering wheel pulls back and forth even though it's in 2wd. I only used 4wd while going off road, would put it back in 2wd if I had to make a tight turn....
Any suggestions?
GnarlyCharlie is offline
post #2 of 5 Old 10-26-2010, 12:54 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you are positive that the T-case is in 2wd, then you probably have a front axle u-joint that needs replacing.
CJ7-Tim is offline
post #3 of 5 Old 10-26-2010, 01:27 PM Thread Starter
GnarlyCharlie
1997 XJ Cherokee
Yeah I'm positive it's in 2wd. It's weird, it was bad right after the trails and it has slowly been getting better. I'll check those U joints this weekend, maybe that's the problem.
Thanks for the advice!
post #4 of 5 Old 10-26-2010, 02:34 PM
Ben
Did you air the tires down, one could be out of balance.
Forget to reconnect the front sway bar?
Mud caked inside the front wheel?
I dunno...
Ben is offline
post #5 of 5 Old 10-26-2010, 02:40 PM Thread Starter
GnarlyCharlie
1997 XJ Cherokee
I dunno...
No it's much more noticeable than any of those things. It feels like when you drive it in 4wd on the street, the way you're not supposed to. Although it is in 2wd. I'm going with bad U joint as of now, but I'll check it out this weekend.
Steering weird? cherokeekid58 XJ Cherokee Technical Forum 1 05-13-2010 01:01 PM
steering feels different after add a leaf wellze XJ Cherokee Technical Forum 2 05-06-2009 12:41 PM
Weird weird Steering issue... beaucaldwell XJ Cherokee Technical Forum 1 02-04-2009 09:35 AM
Suspension feels...weird. Moose_God XJ Cherokee Technical Forum 15 10-16-2004 05:15 PM
Jeep feels weird when I brake kbeckman XJ Cherokee Technical Forum 2 01-21-2002 06:58 PM
