steam or smoke coming from intake and exhust area!
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
iv got either a mix of steam and smoke coming from my intake and exhust, anyone know what this could be? i was thinking maybe oil burning off from leaks in the valve cover, is there coolant passages going though the intake that could be leaking on my exhust,caused by a bad gasket seal? i recently tightened the top manifold bolts because i noticeted that they where finger loose,maybe this did somthing?
#2 |
Seems likely to be a oil leak but I have a thought too you might have bumped a injector and it could be leaking fuel do you smell anything like fuel or burnt oil? No coolant ports run through the intake but if you think its coolant leaking you might have a head gasket leak or cracked head.
Mods 2006 Jeep Wrangler X, 4.0 4:11 gears '90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank A/C Conversion/Home Built Roof Rack/K&N Box Filter Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer Jeep Pic's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
