Steam coming from radiator but not overheating - JeepForum.com
post #1 of 16 Old 11-01-2010, 10:36 AM Thread Starter
Topgun514
1988 XJ Cherokee
Hey everyone, I have a hopefully quick questions about my radiator.
Last night I noticed some steam once I parked at night coming from the front of my radiator. The steam did not smell sweet and I was not driving through any rain, precip, puddles etc. BUT, sometimes I can smell sweet coolant but I figure it is stuff still burning off. I lost about 2 bottle fulls late this summer when my cap went twice causing it to overflow. I can still visually see the antifreeze on a few portions of my engine bay (ONLY from when it exploded, I have a visual memory and when I check these spots they are not from a leak)
I have not seen any leaks and inspected for cracked hoses but all are well. Also, my coolant level has been steady. The only thing I can think of is that with me using my heat more and more now, I am circulating air potentially through the system and maybe I need to burp it again?
Thoughts? Or because it was about 34 degrees when I was driving, there is just a chance it was steam from a hot engine like steam from your breath.
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #2 of 16 Old 11-01-2010, 10:42 AM
RussellZJ98
My engine just recently started up the same issue. Smoke coming from the front right portion of the radiator. Almost by my battery. I cannot find any leaks, but the coolant smell is strong. When I first noticed it there was coolant around my fan. It slowly went away after a couple days, and I thought it had overflowed and burnt off the coolant, but yesterday it started smoking again. I'm curious to see what kind of answer you get. I was going to pull my radiator but I'm not sure it needs to be pulled.
RussellZJ98 is offline
post #3 of 16 Old 11-01-2010, 02:48 PM Thread Starter
Topgun514
1988 XJ Cherokee
I am waiting to see...this issue could be due to just steam coming off hot things at night I am hoping...maybe its time for hood vents
96 XJ Sport- Sold
post #4 of 16 Old 11-01-2010, 04:29 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
As long as your coolant temperature is staying around 200, you shouldn't have to burp it again.
Any antifreeze that was on the engine from late summer should have burned off long ago.
I think you probably have a small leak and you just haven't found it yet.....keep looking as small leaks can turn into very big leaks quickly and then you'll have bigger fish to fry. For leaks, I usually get the vehicle up on a hoist and get a very good light on it and perform a thorough inspection for clues of leakage.
You have an 88 which has a "heater control valve". They can start to leak when they fail and they fail pretty frequently. I would start by inspecting that valve very closely.
And watch the coolant level closely until you find it.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 16 Old 11-01-2010, 04:40 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pressure checking your system would be a good idea to help pinpoint your leak now. Now is always better than later, cuz later you don't know where you'll be when it lets go real good.........
cruiser54 is offline
post #6 of 16 Old 11-01-2010, 09:18 PM Thread Starter
Topgun514
1988 XJ Cherokee
Where is the heater control valve?
I have a spare radiator just chilling in my garage so I will hope its that guy if anything at all.
96 XJ Sport- Sold
post #7 of 16 Old 11-01-2010, 09:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Passenger side of the engine bay. Follow the hoses back from the front of the engine back toward the firewall.
post #8 of 16 Old 11-02-2010, 10:45 AM Thread Starter
Topgun514
1988 XJ Cherokee
Nothing found yet. On a cold night could I start the engine and let it warm and see if the engine bay just steams with condensation or see a leak better under pressure?
96 XJ Sport- Sold
post #9 of 16 Old 11-02-2010, 01:42 PM
medicmandan
medicmandan's Avatar
I chased a leak for two weeks. Pressure tester helped me find it in five minutes. You can borrow one from most of the parts places. I had a hairline crack in one of the plastic tanks.
medicmandan is offline
post #10 of 16 Old 11-03-2010, 01:26 PM Thread Starter
Topgun514
1988 XJ Cherokee
Well if you look infront of cars now here in SLC there is steam coming from out of there headlights. I am still searching for a leak but am trying to stay optimistic about this all.
96 XJ Sport- Sold
post #11 of 16 Old 11-03-2010, 05:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Best to pressure test the cooling system and find the problem before it becomes a huge problem in a not so convenient location.
post #12 of 16 Old 11-03-2010, 05:30 PM Thread Starter
Topgun514
1988 XJ Cherokee
Yeah, will autozone do this? Or midas or something, last time I went to midas they couldnt even test my cap (i refused them to look at anything else- didnt even bring the Jeep, just the cap!!!
And if it is easy and free too, that is a given in the Jeep world of College.
96 XJ Sport- Sold
post #13 of 16 Old 11-03-2010, 10:00 PM
medicmandan
I think they charged my card $100 to borrow the tool which they refunded when I returned it. If you can manage to do it in the parking lot they'll probably just hold your DL.
Where in the valley are you?
post #14 of 16 Old 11-03-2010, 10:41 PM Thread Starter
Topgun514
1988 XJ Cherokee
Salt Lake City, I venture between campus and sugarhouse if you see my jeep, where about you?
96 XJ Sport- Sold
post #15 of 16 Old 01-17-2017, 11:40 AM
Alexis1021
Did you ever figure it out? I've had the EXACT symptoms as you. Steam and wetness coming from the fans.
Alexis1021 is offline
steam or smoke coming from intake and exhust area! rockershocker88 XJ Cherokee Technical Forum 1 11-10-2008 10:35 PM
steam coming through the vents sheera67 XJ Cherokee Technical Forum 8 04-03-2008 02:43 PM
Where is this smell coming from are is my jeep just overheating Justin1805 XJ Cherokee Technical Forum 3 01-31-2008 07:28 PM
Replaced Radiator, still overheating. HELP!! CheechTheJeep XJ Cherokee Technical Forum 11 08-02-2006 05:09 PM
Steam coming from hood...? WayneDolesman XJ Cherokee Technical Forum 3 01-31-2003 01:52 AM
