Starting problems - JeepForum.com
post #1 of 7 Old 02-01-2012, 11:40 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
Starting problems
I have an 83 cCherokee Chief with the AMC 360, D44 front, 4hi/4lo only. I got it as a mud toy and it's never ran since I got It, I went to start in on it and the guy said should run with new fuel, I've turned it ivermectin by hand to make sure it wasn't locked up, good oil, full of coolant, clean trans fluid. I went to start it and nuthin, not even a click out of the starter, I took the starter off and hocked it to a battery and got nuthin. So that starter is bad, but I also didn't hear my solenoid click which I thought was weird since the interior lights are all working.
Any thoughts please let me know.
if you know for sure what rear end it has and the gear ratio. I was told GM12
And what trans and t-case it has in it.
Thanks.
4x4cherokee4x4 is offline
post #2 of 7 Old 02-01-2012, 12:36 PM
Fishs95XJ
1995 XJ Cherokee
Did you try replacing the starter? Even if the starter is bad all of the other lights in the jeep will work fine..
Fishs95XJ is offline
post #3 of 7 Old 02-01-2012, 02:13 PM
Its_A_JeepThing
This is very true it has happened to me.! left me stumped replaced starter and she fired up after a little bit of hesitation. Good Luck!
Its A Jeep Thing- SO GET ONE!
ONLYJEEPPARTS.COM
Its_A_JeepThing is offline
post #4 of 7 Old 02-02-2012, 07:33 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
Ya im getting starter Saturday, so hopefully that's it.
post #5 of 7 Old 02-02-2012, 07:42 AM
Its_A_JeepThing
good luck!
ONLYJEEPPARTS.COM
post #6 of 7 Old 02-03-2012, 07:40 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
So I got the starter to work, I jumped the solenoid and it weakly turned over. But the battery I was using was at 80% and was a semi battery, but only had 750 cca. I'm guna replace the solenoid and try it again with my truck battery, 940cca should do it lol. Any other ideas why it would be a weak crank over? I had a semi battery with a battery charger on start hocked up tp it.
post #7 of 7 Old 02-07-2012, 09:24 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
So Its cranking over strong now, but I don't have any spark. I replaced the coil, plugs, cap and button, still nuthin. I'm getting power to the coil, but nuthin from it. I'm thinkin about replacing wires. If it still has nonspark does any one have an idea?
solenoid , starter issue , transfer case , transmission
steering problems stang-4 Forum Software Test Section 1 01-18-2010 12:36 PM
