Starting problems - JeepForum.com
post #1 of 6 Old 10-20-2011, 07:51 AM Thread Starter
snuffandstuff
Starting problems
I am having trouble finding what the problem is with the start. the engine cranks but it doesnt turn over. ive replaced the starter put in a new battery and also replaced the CPS. Im running out of options and its starting to drain the money so if someone could help that would be great! its a 4.0 liter with 124k on it... Thanks!
snuffandstuff is offline
post #2 of 6 Old 10-20-2011, 07:56 AM
MarkwithaK
Had this same issue when I bought my XJ, ended up being the coil.
MarkwithaK is offline
post #3 of 6 Old 10-20-2011, 08:05 AM Thread Starter
snuffandstuff
ill check that as well thanks. any other suggestions?
post #4 of 6 Old 10-20-2011, 08:35 AM
GtiKyle
Check for spark : Pull a spark plug, and place on an engine ground...crank and watch for spark.
Are you getting fuel? - smell like fuel? you could also pull an injector to see if squirting.
Check all grounds - Clean and sand your grounds to make sure your ECU is getting good voltage.
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #5 of 6 Old 10-20-2011, 08:40 AM Thread Starter
snuffandstuff
yeah i can definitely smell fuel. i dont know if it makes any difference but i left it overnight and it started the next day. i turned it off and went to start it again and it just cranks but doesnt catch. im gonna go to advance auto and get a new coil and see if thats it.
post #6 of 6 Old 10-20-2011, 01:18 PM
Paradise XJ
1988 MJ Comanche
Just see if there is fuel pressure to the fuel rail. Use a fuel pressure gauge for accurate info.
I don't know about pulling an injector to see if it's squirting. In my experience, the coil is not usually the problem...more like the CPS...which is why you need to check for spark first.
Then...spark + fuel + air = vrooom! Simple.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
start problems , starting , starting issue
Starting problems apoto11 XJ Cherokee Technical Forum 5 08-11-2008 11:01 AM
Problems Re-starting!! santosdv XJ Cherokee Technical Forum 1 08-11-2008 10:59 AM
Does anyone else have as many starting problems as me? HeavyMetal XJ Cherokee Technical Forum 4 03-09-2007 07:38 AM
Starting Problems WAKETEK516 XJ Cherokee Technical Forum 6 05-01-2006 02:19 PM
starting problems joemomma XJ Cherokee Technical Forum 4 11-04-2002 08:03 PM
