Quantcast Starting Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Starting Issue
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-11-2008, 11:48 PM   #1
Dannyboy18
Starting Issue
I've had a weird problem lately... I start my Jeep for the first time of the day (so engine is cold) and it starts fine, no issues
Then, if I turn it off at a gas station or something, when I go to crank it over a couple minutes later, it won't do anything when I go to crank it; all the lights appear and such, but the starter does nothing.
If I put it in Neutral rather than Park, it will start just fine. The start SOUNDS fine and everything.
What could this be? Neutral Safety Switch maybe?
Keep in mind that this started happening when it got cold here in Missouri. It's usually between 20 and 35 *F.
Note: this is kind of weird since my brother's Jeep had a very similar problem a week or so ago; the difference was his would NOT start in Neutral, turns out his entire starter was bad.
Thanks.
-Dan P.
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline   Reply With Quote
Old 12-12-2008, 12:44 AM   #2
OffSgt
Yes
OffSgt is offline   Reply With Quote
Old 12-12-2008, 05:42 AM   #3
tjwalker
It's the crank sensor!
tjwalker's Avatar
Yours does sound like the neutral safety switch. They can be cleaned/rebuilt if you want; new ones are kind of spendy. Use the SEARCH function for more information on the neutral safety switch (NSS)
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 12-12-2008, 08:14 AM   #4
lziel590
1989 XJ Cherokee
making it easier for you - http://jeepin.com/features/nss/index.asp
lziel590 is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
