Quantcast starting issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > starting issue
Free Shipping on all Engo Winches Continues...starting at Black Magic Brakes - 5% Off, No Minimum Purchase RequiredOfficial Chassis Saver Rust Preventive Truck & Auto Un
Old 09-14-2008, 10:39 PM   #1
89SAFARIXJ
1989 XJ Cherokee
starting issue
it takes about 5 seconds atleast after i turn the key in my xj for the rig to actually start. it just turns over and over and over...... ..... ... .. ...and then it starts.
everybody says, "it's just old."
well i dont like having to worry if it will start everytime i turn the key. and i figure there is something i can do to make it turn for less then a second and BAM start just like that.
starter?
plugs?
wires?
there has to be something. anybody have this problem or have any suggestions?
1989 Jeep Cherokee Laredo Build
89SAFARIXJ is offline   Reply With Quote
Old 09-14-2008, 11:54 PM   #2
dcorn
Do the whole upgrade kit. Summit sells an Accel kit that has a cap, rotor, plugs and wires. It's only 60 bucks and couldn't hurt.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 09-15-2008, 01:03 AM   #3
89SAFARIXJ
1989 XJ Cherokee
thanks man im sure it needs something like that since its an 89. i will have to check that out.
people say it cant be the starter. just wondering, could the starter have anything to do with it in your opinion?
Old 09-15-2008, 05:37 AM   #4
dcorn
If it hasn't ever been replaced, it could help, but I've heard the long start is a common issue with Jeeps.
Old 09-15-2008, 07:40 AM   #5
kadetklapp
2008 MK Patriot
If the starter is turning the motor over with out a problem, then it's fine. The starter has nothing to do with ignition.
The problem you have is either ignition or fuel. I'd check fuel pressure as well as spark. On an old Renix XJ I'd suggest R&R'ing your distributor cap and rotor, plugs, wires, and check your coil for corrosion (coils seem to be a weak point on the old 4.0s).
**edit
If your motor is cranking SLOWLY and that's why it's taking so long to catch then it could be the starter, or perhaps a weak battery.
**2008 Jeep Patriot Limited 4x4**
60k, *Absolute Rubish*
Former-
2004 Jeep Grand Cherokee Special Edition 4x4 V8.
1999 Jeep Cherokee SE
kadetklapp is offline   Reply With Quote
Old 09-15-2008, 07:47 AM   #6
tjwalker
It's the crank sensor!
tjwalker's Avatar
Renix model XJs by design do have a longer crank time than later model ones but I don't know if it is 5 seconds or not. Somebody else should chime in on that.
Generically speaking, long crank times are often tied to a loss of fuel pressure at the fuel rail; thus it takes the cranking to build up enough pressure to start. If you are concerned about this, I would conduct some fuel pressure testing, both running and not running (dynamic/static) and compare your results to factory spec.
Your symptoms do NOT point to a starter or starting circuit problem of any kind.
Good Luck!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 09-15-2008, 11:52 AM   #7
scupking
1994 XJ Cherokee
Dose it start fast the rest of the day? Mine dose the long crank first start of the day. Everyone I talked to said don't worry about it, it's a jeep thing.
scupking is offline   Reply With Quote
Old 09-15-2008, 09:36 PM   #8
123mylesl
1997 XJ Cherokee
Before you purchase anything check to make sure the distributor cap is not loose, if it is tighten the screws back up. A loose distributor cap throws the timing off. If not this purchase the accel kit
123mylesl is offline   Reply With Quote
Old 09-15-2008, 10:53 PM   #9
89SAFARIXJ
1989 XJ Cherokee
its starts slow all day...
Old 09-15-2008, 11:14 PM   #10
lifted89xj
1989 MJ Comanche
Good Luck!
my jeep does that u crank and it wont start then you try again then touch the gas pedal then it fires up. yes its fuel injected.
lifted89xj is offline   Reply With Quote
Glock Forum
