Starter? Starter Relay? - JeepForum.com
post #1 of 17 Old 05-09-2007, 07:23 AM Thread Starter
bills79jeep
My Jeep is DEAD as of this morning. The battery gauge shows 12v and when I turn the key absolutely nothing happens. At Autozone, a starter relay is only $8.99 while a starter is like $70. Previous to today I have had zero problems with starting. When other starters have died, they have had slow deaths. That's why I'm thinking possibly the relay.
Any ideas? Also, is the relay in the engine compartent fuse box or the one on the passenger side by the door?
2005 Grand Cherokee Laredo 3.7L, stock
1979 CJ-5 AMC V8
1998 Cherokee 4.0L - Sold
bills79jeep is offline
post #2 of 17 Old 05-09-2007, 07:35 AM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
You can jump the starter relay with a piece of wire around 3' long. Just touch it to the positive terminal on the battery & to the wire going to the starter solenoid on the relay (thick green wire?). If it starts that way, then you know your starter is good & it's probably the starter relay or the box on the column. (Put your key in "run" & jump it to have it start the motor.)
Have you had any problems with your reverse lights?
It could also be your NSS, try starting it in neutral & moving the shifter while turning the key.
97 ZJ Limited, all power V8 AWD (wife's DD)
93 XJ Country 32" TSL Radials, 4.5" Rough Country Lift
91 XJ Laredo 33x15.5 TSL SXs, Homebrew 3" lift
Local to Cincinnati, Ohio? Check out our club!
jfiscus is offline
post #3 of 17 Old 05-09-2007, 09:21 AM
96yeepster
or swap it for another relay that is in the same area... IE A/C, fan...
96yeepster is offline
post #4 of 17 Old 05-09-2007, 09:55 AM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
That is not the starter relay I am speaking of, I mean the one with all the wires attached to posts on it. You are speaking of the fuse panel, correct?
jfiscus is offline
post #5 of 17 Old 05-09-2007, 10:56 AM Thread Starter
bills79jeep
The one in the fuse panel, which fuse panel are you refering to? Also, could I bypass it with some wires with alligator clips? Or does it need to be pretty heavy gauge?
Thanks guys.
1979 CJ-5 AMC V8
post #6 of 17 Old 05-09-2007, 11:10 AM
TwoOne
Mine did this to me, which I think was a result of bad wiring, in the end after replacing the starter solenoid and doing a whole bunch of messing around I ended up just wiring a pushbutton starter switch to where I just turn the key on, push the button and it cranks. Pretty good theft deturrent as well because you can't plainly see where the button is
Louis
99 WJ Limited
TwoOne is offline
post #7 of 17 Old 05-09-2007, 12:34 PM
96yeepster
there is only one starter relay.
It (depending on year) like on my 96 is under the hood in the power distribution block.
It is a compact rectangular 5 pin type.
What I think you are referring to is the starter selinoid, which is actually mounted on the starter. If that goes bad it will also create a no start situation, however, you might want to check to make sure the selinoid is getting voltage reference from the ignition wire.
I would only install a bypass if you cannot find an obvious cause for the problem.
I have seen alot of people do it wrong and it ends up causing a fire that destroys the car.
I am not dissing anyone here who has done one, but I hate it when I get a vehicle and have to fix stupid crap like that that someone has done instead of actually fixing the problem correctly.
post #8 of 17 Old 05-09-2007, 12:54 PM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
I know this photo is of an 89, but I have one on my 93 XJ in the same location:
http://autorepair.about.com/library/images/bl347lib.htm
Check for one, it's kind of hidden right behind the battery. I know it's there and a common problem, as I've had a couple go bad on a couple different XJs.
The starter solenoid is down on the starter on every year of XJ, besides possibly diesels - I never replaced my diesel's starter.
jfiscus is offline
post #9 of 17 Old 05-09-2007, 03:14 PM Thread Starter
bills79jeep
Thanks guys, you have all been a big help, I am going to go to autozone and get some parts. I have a Haynes manual that will hopefully help, though it is crappy and usually doesn't.
1979 CJ-5 AMC V8
post #10 of 17 Old 05-09-2007, 04:34 PM Thread Starter
bills79jeep
Which realy is it on a '98. Mine doesn't look like the picture.
1979 CJ-5 AMC V8
post #11 of 17 Old 05-09-2007, 05:47 PM
XJdamyankee
Look in your haynes or try your owners manual. One of the 2 should have a pic of it. Before you go buy something you dont need just figure out which one it is and switch it with another one thats in there. I believe thier are 3 in there that use the same kind.
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline
post #12 of 17 Old 05-09-2007, 06:11 PM
red96jeep
sounds like the same thing that was happing to my jeep not to long ago. is their power going into the relay box from the ignition? mine didnt have any so i just bought a new ignition piece and put it in. that seemed to fix it. but every now and then it happen's again so i assume it's an eletrical gremlin that i will never fix.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline
post #13 of 17 Old 05-09-2007, 06:57 PM Thread Starter
bills79jeep
Ok, so I installed the new starter after the new relay did nothing. It didn't work either, so I gave it a few taps with a hammer and it started up. My friend that works at a Jeep dealership said that this means that it is a faulty starter and I should exchange it for another new one.
Anyone have any advice on this?
1979 CJ-5 AMC V8
post #14 of 17 Old 05-09-2007, 07:30 PM
KamekLocked
KamekLocked's Avatar
Yeah sticking starter could be the brushes, etc. Does it go 'click' when you try to start it??? That means the solenoid is engadging but the starter motor is faulty (or not enough voltage rom the battery, bad batter terminals, bad wiring to starter, or bad ground).
All you really had to do is check for power at the start terminal of the solenoid when they key is in the crank position and that will either tell you the starting cirucit (ignition, nss, starter relay and wiring) is operating fine to that point or not. 10 seconds would save you hours of useless troubleshooting.
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline
post #15 of 17 Old 05-09-2007, 08:00 PM
Goldenknob
2007 WK
I had the same problem a few weeks ago.. I ended up replacing my ground cable from battery to engine block and that was my problem... everything else worked, just the engine wouldn't turn over or click or anything, only click I had was ignition relay. check your battery cables to engine block and to starter to see if they are damaged or loose.
Goldenknob is offline
starter relay GrandJoker XJ Cherokee Technical Forum 4 01-22-2010 10:24 AM
starter relay GrandJoker XJ Cherokee Technical Forum 0 01-22-2010 09:26 AM
starter relay mlelah XJ Cherokee Technical Forum 1 10-22-2008 09:02 PM
starter relay xjpete XJ Cherokee Technical Forum 4 03-29-2008 08:18 PM
Starter Relay Flanz XJ Cherokee Technical Forum 4 08-18-2004 05:52 PM
