is it the starter or something else -
post #1 of 2 Old 08-29-2011, 08:29 AM Thread Starter
i have a 96 xj auto and im having problems with getting her started. about a week ago i got back from a trip taking it about 200 miles away and the next day i went to start it to go to work and nothing happened. i got power on the dash and my radio turned on it just wouldnt crank. the battery says its only 2 years old. so i let it sit for a week til i got my paycheck and yesterday i went to check to see if its the nns i just happened to try to turn it on normally and it started just fine would this be a problem with a starter? i just dont want to go out and start blowing money on parts unnecessarily
snuffandstuff is offline
post #2 of 2 Old 08-29-2011, 08:34 AM
1997 XJ Cherokee
It is possible, those mini's aren't very reliable IMO. The next time it acts up crawl under and rap on the starter a few times with a hammer, normally it's the brush's shorting and the pounding temporarily fixes the short. If it starts right away after that then your starter is more than likely failing and will need to be replaced before it leaves you stranded somewhere.
97' Cherokee sport 2 DR / 4.0 Power Tech, 5 spd MAN, Command trac / Dana M30/181MM front axel, Corporate 8.25 rear axel / 6.5" Bastard lift, 31X10.5 Daytona futura's on Cragar 15X8 soft 8's, Logans Metals Front winch bumper, Flowmaster super 44, Magnoflow high flow cat
bdodge is offline
start problems , starter , starter issue , xj
In order to be able to post messages on the forums, you must first register.
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 02:45 PM
starter? jeep12827 XJ Cherokee Technical Forum 8 06-04-2008 09:52 PM
Starter, will one from an '89 fit a '96? Ben XJ Cherokee Technical Forum 2 04-29-2008 11:24 AM
Best starter to buy cnskate XJ Cherokee Technical Forum 14 01-08-2008 03:04 PM
Starter? Starter Relay? bills79jeep XJ Cherokee Technical Forum 16 05-10-2007 02:09 PM
