Starter relay clicks = neutral switch, etc OK ? - JeepForum.com
post #1 of 3 Old 12-26-2012, 01:15 PM Thread Starter
DCLoppy
Hi, trying to help remotely diagnose a no-crank situation. Looks like a bad starter or bad connections, but would like some input from the good folks here.
When the key is turned there is either no click or an occasional click - no signs of turning. Lights stay bright ( and battery voltage is good).
The relay under the hood DOES click when the key is turned - can I assume that this means that the neutral switch ( and maybe others)? are OK.
Other than the starter and the battery cable and ground connections - anything else to check before replacing the starter?
DCLoppy is offline
post #2 of 3 Old 12-26-2012, 01:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Clicking and not starting is usually a low voltage issue from:
  • leaving the lights on
  • a failing battery
  • a failing alternator
  • dirty or loose wire connections
  • internally corroded battery wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed.
Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Place your DVOM (Digital Volt Ohm Multi-Meter) on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then we have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+ stud = 0.5 volt with maximum charging load applied (all accessories turned on)
Test the output at the alternator. You should be measuring 13.8-14.4 volts. Load testing the alternator is still recommended.
Exchange the ASD relay with the Starter relay in the fuse box under the hood near the battery.
Wiggle the automatic transmission lever in both Park and Neutral while trying to start. If it starts, you need to clean or replace the Neutral Safety Switch (NSS).
Have your helper turn the ignition key to START while you tap on the starter with a hammer. If the engine starts, you probably need a new starter.
Have the battery, starter, and the alternator Load Tested for proper function in a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
CJ7-Tim is offline
post #3 of 3 Old 12-28-2012, 06:42 AM Thread Starter
DCLoppy
Tim, thanks for the input -I had always said "tap with hammer" and then start. However following your advice of hammer while starting ( two people obviously) we got some noise and whine - not enough to start but enough to convince me to immediately replace the starter. After replacement - what a difference! We have owned this jeep (1988) for 5 years, and it always turned over slowly - always started - and I assumed that was the jeep way. NOW - cranks like a normal car.
DCLoppy is offline
