Starter Issues..new starter... ground issue maybe..?? - JeepForum.com
post #1 of 6 Old 05-29-2012, 07:27 PM Thread Starter
Camfam07
So my wife recentlty took my jeep to work while I did some work on her car, well she calls me , JEEP wont start, I went up there tried to jump it and arc the starter and solenoid got nothing so I replaced the starter and got it started we stopped at sonic on the way home and went to turn the engine over and nothing! just clicked... turned it off and back on nothing again... click, played around with the battery and grounds and wires and a little bit, finally started up, I brought it home and cleaned up all the muddy and dirty wires, its been starting fine but today it dit it again, wiggled the wires and it started again, yes sound like a short but there is no burnt, or exposed wires that I can see.... does anyone else have any other ideas what this could be?
Last edited by Camfam07; 05-29-2012 at 07:32 PM. Reason: punctuation and corrected spelling.
Camfam07 is offline
post #2 of 6 Old 05-29-2012, 07:42 PM
Diamond-x
1991 XJ Cherokee
There are two terminals on the starter motor, the power from the battery and the solenoid activation from the ignition switch. Connect a fresh wire from the solenoid and tap it on the positive battery terminal. If it turns over your issue is with the wiring between the ignition switch and the solenoid.
Hope this helps
Diamond-x is offline
post #3 of 6 Old 05-30-2012, 07:35 PM Thread Starter
Camfam07
Hope this helps
Now I have used a screw driver to touch the 2 together and when this happens it clicks and sparks but never turns over, I dont know if im getting enough connection on it, but has to be a short somewhere, because all I have to do is wiggles wires around and it will start up, gotta be a wire somewhere I think.
Camfam07 is offline
post #4 of 6 Old 05-30-2012, 10:46 PM
BleepinJeep
1988 XJ Cherokee
A dead battery also, are your battery posts and connections clean?
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #5 of 6 Old 05-31-2012, 07:52 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you bought your rebuilt starter at Advance/IdiotZone/O'Reilly's be aware that poorly rebuilt starters and early failure is not uncommon.
Clicking and not starting is usually a low voltage issue from:
leaving the lights on
a failing battery
a failing alternator
dirty or loose wire connections
internally corroded wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Wiggle the automatic transmission lever in both Park and Neutral while trying to start. If it starts, you need to clean or replace the Neutral Safety Switch (NSS).
Have your helper turn the ignition key to START while you tap on the starter with a hammer. If the engine starts, you probably need a new starter.
Have the battery, starter, and the alternator Load Tested for proper function in a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
CJ7-Tim is offline
post #6 of 6 Old 06-03-2012, 10:25 AM Thread Starter
Camfam07
Thank you very much, so far after re-checking and cleaning everything it has not happened again, I think im gonna by new wires/battery terminals anyways mine are pretty rough shape, thanks for the info!
Camfam07 is offline
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 02:45 PM
Starter issue or????? BUSCHLIGHTRULES XJ Cherokee Technical Forum 2 12-06-2011 04:36 PM
battery/starter/ground refreshing cable connections...dielectric grease? XJay97 XJ Cherokee Technical Forum 6 09-27-2011 05:57 PM
Starter issue Jason845 XJ Cherokee Technical Forum 3 11-07-2009 12:05 PM
Starter issue on XJ screwrice XJ Cherokee Technical Forum 3 02-23-2009 05:48 PM
