starter? - JeepForum.com
post #1 of 9 Old 06-03-2008, 07:27 PM Thread Starter
jeep12827
1987 XJ Cherokee
starter?
hey guys, well i just went out to start my jeep for the second time today, and when i turn the key, i hear just a little click, and there is nothing, i think its the starter? or could it also be the starter solenoid?? my only question with the starter begin bad is wont u have a few probelsm with it before it totally locks up? this is my only problem iv ever had wit the starting.. if you guys know anyuthing about it I appreciate it and if u could get me a short write up of how to replace them..
thanks
jeep12827 is offline
post #2 of 9 Old 06-03-2008, 07:55 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
check all the wires going to the starter to make sure they are clean and tight,also check your battery terminal connections. if these all check out fine my money would be on the solenoid.
xjfever is offline
post #3 of 9 Old 06-03-2008, 08:18 PM Thread Starter
jeep12827
1987 XJ Cherokee
yeah, new wiring going to battery and where exactly is the starter abd solenoid located on these? does anyone have a writeup on replacing them?
post #4 of 9 Old 06-03-2008, 10:44 PM
ehall
1991 XJ Cherokee
What year? The 84-90 Renix has a different solenoid setup than the 91+ setup...
ehall is offline
post #5 of 9 Old 06-03-2008, 10:56 PM
KamekLocked
KamekLocked's Avatar
Use a DVOM not the jumper cables to test electrical circuits...Chances are your battery is weak and you need a new one, or the alternator is not operating correctly. Hitting a permanant magnet starter is bad but as long as it isn't smashed too hard you will be able to tell if the brushes are stickng if the starter works from hitting it... An AVR test would tell you a lot as well.
Using the jumper cable method would be last resort...
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline
post #6 of 9 Old 06-03-2008, 11:20 PM
Broken_Soldier
If you have an auto tranny, first thing to check is that the shifter is in park, not reverse or drive. Sounds dumb, but she wont start in those positions.
Strength and honor.
Broken_Soldier is offline
post #7 of 9 Old 06-03-2008, 11:49 PM
ehall
1991 XJ Cherokee
she also won't go "clunk"
ehall is offline
post #8 of 9 Old 06-04-2008, 05:20 AM Thread Starter
jeep12827
1987 XJ Cherokee
thanks everyone, it is an 87 with the 4.0 sorry i left that out, and the noice is just a little click, not a clunk
post #9 of 9 Old 06-04-2008, 09:52 PM
bikedude189
1993 XJ Cherokee
my money would be starter or low battery voltage. since you can hear the click(solenoid closing) i would guess not the solenoid. i've had to replace starters twice (different jeeps) sometimes the hammer trick works, sometimes not. check your battery, if the voltage is fine...
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 02:45 PM
Starter Bad? mfinkler XJ Cherokee Technical Forum 5 11-24-2009 06:17 PM
Where is the starter? 88 xj Thmastr XJ Cherokee Technical Forum 13 12-06-2008 12:24 AM
Starter? Starter Relay? bills79jeep XJ Cherokee Technical Forum 16 05-10-2007 02:09 PM
Starter? mdonohu1 XJ Cherokee Technical Forum 4 01-04-2007 06:47 AM
