Started my lift install - JeepForum.com
post #1 of 6 Old 01-10-2007, 10:55 PM Thread Starter
poolmike
1966 CJ5
I decided to start my lift install Wednesday morning. So far, the XJ has owned me.
I broke the driver's side sway bar end link and had to cut the rear bolt out of the lower control arm since it rusted to the bushing sleeve. Tomorrow, I'll start out doing a parts run...new end links, all new control arm bolts, get some longer brake hoses made up...and see if I can get the front end finished and maybe start on the rear.
'66 CJ5 nasty, rusty project.
'98 ZJ Limited. 5.2L, Auto. Stock for now.
poolmike is offline
post #2 of 6 Old 01-10-2007, 11:00 PM
craminator66
Thats too bad to hear. It can be a pain, just hang in there....maybe the rest will go like butter.
00' XJ (lift, tires, HP dana 30 4.10's, Aussie Locker in front)
craminator66 is offline
post #3 of 6 Old 01-11-2007, 03:59 PM Thread Starter
poolmike
1966 CJ5
WOW! This job is kicking my ... Anywho, The lower control arm bolts that go thru the frame were rusted to the bushings. Normally it wouldn't be a big deal, but my buddy borrowed my angle grinder...so I had to go pick that up first. Other than that, it is going well.
Tomorrow I start on the back end. Shocks and add a leaf. I can't wait to see what happens with those upper shock bolts.
poolmike is offline
post #4 of 6 Old 01-11-2007, 04:38 PM
XJHERO
XJHERO's Avatar
Originally Posted by poolmike
... I can't wait to see what happens with those upper shock bolts...
I could tell you but then it wouldnt be a surprise!
98 XJ.
4.0 HO - AW4 - NP 231 - DANA 30, CHRYSLER 8.25
4.5" RE SUPER FLEX KIT, 32x11.50 BFG KM's
DIFF GUARDS, ENGINE AND TRANS SKID, CB
XJHERO is offline
post #5 of 6 Old 01-11-2007, 04:46 PM
RussoGuitar
1989 XJ Cherokee
just get plenty of PB on the upper shock bolts from the top (through the access ports next to the upper mounts.) Ive done shocks changes/lifts on a couple rusted xj's and ive only broken one bolt.
RussoGuitar is offline
post #6 of 6 Old 01-11-2007, 08:35 PM Thread Starter
poolmike
1966 CJ5
I've been soaking everything 3 times a week for the past month. It seems to have helped on everything except two of the control arm bolts. Hopefully I can get it wrapped up tomorrow and to the tire shop on Saturday.
poolmike is offline
Started 2010 with a lift install 303_XJ XJ/MJ Cherokee Non-Technical Forum 31 01-06-2010 11:59 AM
3 pics so far, started 6.5 lift & 35's Billet XJ/MJ Cherokee Non-Technical Forum 35 02-01-2009 02:27 PM
So I started installing the lift today..... Wolf92XJ XJ Cherokee Technical Forum 13 04-02-2007 04:43 AM
Started installing TnT Lift Rodimus XJ Cherokee Technical Forum 4 12-23-2006 03:34 PM
Started my lift on the cheap shylow XJ Cherokee Technical Forum 1 02-14-2005 06:20 PM
