Started with the common CPS/CKP failure and now is Completely out of hand - Page 2 - JeepForum.com
post #16 of 26 Old 07-10-2012, 01:04 AM
Kiplinger
1997 XJ Cherokee
My CPS went out on the interstate periodically chirping the back tires as it cut the ignition. 60 mile round trip made for a real a@@pain, got a new distributor from twilight zone because they didn't offer the CPS and it failed within a week so i just swapped the sensors and it's worked great three years now.
Kiplinger is offline
post #17 of 26 Old 07-10-2012, 06:49 AM
Azzy
Originally Posted by Nate_nev View Post
got my TPS and CPS from nappa as a rfiend works there and i get parts for cost... tomorrow I am checking for cracks in the flywheel, if there are none, then I will go to the dealer.. even though I do have a hard time reasoning with the new sensors being non compatible because of being aftermarket. Is this a truly common thing with these cherokees?
It isnt because they are aftermarket, its because they are made in a slave workshop for pennies, and are like most things that end up on the shelf at Harbor freight... cheap Chinese crap. Occasionally you will get a good one, but that isnt the norm.
Napa sells 2 CPS units, one is ~$30, one is ~$70. the more expensive of the 2 is made by a trusted NAPA supplier, and not one of the poor quality companies.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #18 of 26 Old 07-11-2012, 10:33 AM Thread Starter
Nate_nev
1997 XJ Cherokee
Checked the trans pan and no abnormal shavings, I guess the next step is the dealership to get a CPS from them.. I will update on if it is a success or not. If it is a success... at least I have a whole lot of spare sensors!
I'd also like to thank everyone for the input and help so far!
Nate_nev is offline
post #19 of 26 Old 07-29-2012, 04:13 PM Thread Starter
Nate_nev
1997 XJ Cherokee
changed the sensors, still doing the same thing.... I am left in the situation where I need to ask, can I take a motor from a 1995 grand cherokee and put it in my 1997 Xj?
Nate_nev is offline
post #20 of 26 Old 08-01-2012, 02:51 PM Thread Starter
Nate_nev
1997 XJ Cherokee
changed the Idle Air valve, doesnt stall anymore... but sputters at 50-60km/hr.. any ideas that I haven't tried? i've also retraced all wires, grounds.. got a bit of flack for wanting to change the motor.. so lets fix it! LOL
Nate_nev is offline
post #21 of 26 Old 08-01-2012, 03:00 PM
Diamond-x
1991 XJ Cherokee
Have you checked both grounds? The strap from the rear of the head to the body and the one just rear of the distributor on the side of the engine block.
I've had problems with the engine running smoothly when these were not clean and tight.
Just a thought.
Diamond-x is offline
post #22 of 26 Old 08-01-2012, 03:03 PM Thread Starter
Nate_nev
1997 XJ Cherokee
yes, and shaved the contacts and contact poins "shiny"
Nate_nev is offline
post #23 of 26 Old 08-02-2012, 07:28 AM Thread Starter
Nate_nev
1997 XJ Cherokee
I WIN!!!! LOL, (sorry for the caps)... Last night I decided to re-check the fuel pressure and I watched my gauge "stick" then move.. so I went to canadian tire and bought a new gauge, hooked it up and 52 PSI, turned the Jeep off and watched the pressure gauge almost instantly drop to 10 psi. Called around to figure how much a fuel pressure regulator would be and was quoted $230... I then called the USA parts store seeing how I am on a border town.. and $80.. SOLD put her in with a little hassle and fixed. holding pressure and not stalling stuttering or anything.. kind of annoyed about this but I did find a lot of little problems that could have left me stranded in the bush at some point like wires melted to the exhaust etc.. so at least most things are now new!
I would like to thank everyone's input and help!
Nate_nev is offline
post #24 of 26 Old 08-02-2012, 08:41 AM
Kiplinger
1997 XJ Cherokee
Awesome work, but being stranded in the bush isn't always bad HA!! Beer:30 here cheers and congrats!
post #25 of 26 Old 10-22-2012, 06:50 PM
OnTheFence
Wow, way to stick with it.
Nate, is the fuel pressure regulator part of the fuel pump or fuel filter?
Is this an easy part to change out?
OnTheFence is offline
post #26 of 26 Old 10-24-2012, 12:32 PM Thread Starter
Nate_nev
1997 XJ Cherokee
its top of the tank, release the straps and it is right on top, i will take a picture if you want and email it to you. pm me your email.
Nate_nev is offline
bucking , high idle , stalling
ac high pressure hose failure. is it common? yepits2wd XJ Cherokee Technical Forum 21 06-09-2011 10:31 PM
completely stuck Winkler121 XJ Cherokee Technical Forum 28 09-25-2010 02:02 PM
Started my cherokee and started ticking bad TEXASBOY XJ Cherokee Technical Forum 10 10-13-2009 03:51 PM
convert left hand to right hand drive xj95mj88 XJ Cherokee Technical Forum 10 08-27-2009 01:18 AM
Blinkers completely out epug88 XJ Cherokee Technical Forum 1 11-26-2008 02:59 PM
