Stalling out while driving - alternator ? - JeepForum.com
post #1 of 3 Old 06-09-2007, 07:53 PM Thread Starter
JohnnyQuest
Hi everyone,
I'm hoping someone might be able to help me figure out what's going on with my Jeep.
I was driving home today from the store, and it basically started acting like it was possessed... it would cut out for no reason, especially at stop signs etc, then I could put it in neutral and it would start back up, go a few hundred more yards, same thing etc.
Was hoping to limp it home but, it got progressively worse so now it's sitting in an empty lot about a mile from my house.
It's very strange... for the most part all the lights / radio etc work, but then all of a sudden everything will go completely dead. Then the interior lights will come on, and it will start, then sorta just "chug a lug" for about 30 seconds then die again.
I'm pretty sure it's not the battery, it's less than a year old, and like I said all the lights etc seem to work fine.
I'm thinking its probably the alternator, my Honda accord did the same thing and I had to replace the alternator on it.
I am wondering though, if there is any way a bad battery cable could cause the same type of symptoms ?
I ask because, about a month ago, I stopped to get gas, got back in, and everything was totally dead, no inside lights etc. I looked under the hood, and noticed that the negative battery cable was a bit loose, I had just replaced the terminals a few days before.
So, when that happened, I tightened it all down good etc, and it started right up with no problems. But I did notice that the negative cable looked pretty corroded and put it on my list to replace when I get a chance.
So... that's my situation, if anyone has any ideas/thoughts/similar experiences, I would definitely appreciate it.
Thanks in advance,
JD
1996 Cherokee Sport 4WD 4-Door... stock (for now)
JohnnyQuest is offline
post #2 of 3 Old 06-09-2007, 08:49 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
What kind of battery clamps do you use. If it those that clamp down on the exposed cable then there could be connection problems. I'm not sure why it would stall if the cable looses connection then the alternator should keep you driving unless there is maybe too much of a draw on the alternator at idle.
Check the voltage at the battery post then try checking on the cable to check for resistance. Then if you get it started again check voltage again for charging, it should read higher by up to 2 volts.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #3 of 3 Old 06-10-2007, 12:48 PM Thread Starter
JohnnyQuest
Thanks, I was too busy trying not to get run over I didn't even look at the volt gauge etc...
I will try what you said, maybe I will get lucky and it's just a cable or something.
Thanks again,
JD
Weird stalling problem. I'm thinking alternator. pixelbend XJ Cherokee Technical Forum 11 01-15-2010 12:36 PM
98 Classic Randomly cuts out while driving, random rough idle and stalling. HELP! 4x4xjCREW XJ Cherokee Technical Forum 19 12-06-2009 11:57 AM
Alarm and stalling when driving! HELP B1GFUN XJ Cherokee Technical Forum 7 02-05-2008 06:41 PM
Voltage dropped while driving, then couldn't start... bad alternator? patchouli XJ Cherokee Technical Forum 6 11-25-2007 10:13 PM
Cherokee stalling after 3-4 hours mail route driving bdobbi XJ Cherokee Technical Forum 16 01-31-2005 01:49 PM
