Squealing/squeaking noise until I press brakes? - JeepForum.com
post #1 of 7 Old 03-24-2012, 06:47 AM Thread Starter
mreid10
My 1996 xj was in the shop for the past two weeks because they put a couple washers on a sway bar bolt and then they replaced my left side "heim" joint which is just a tie rod and when I drove my jeep away from the shop yesterday there is this VERY loud squealing/squeaking noise when I drive but it stop when I press the brake. Of course it does get louder as I drive faster and it sounds like it's coming from the front driver's side. It definitely did not make this sound when I brought it to the shop but it did sit there for two weeks while the heim joint was shipped in. It's so loud I feel bad for anyone I drive by haha. Any ideas?
mreid10 is offline
post #2 of 7 Old 03-24-2012, 11:49 AM
AZ Jeff
2014 JK Wrangler
If it goes away when the brakes are depressed (even slightly), it sounds like caliper pad squeal is the issue. They make a goop that can be applied between the pad and the caliper to lessen/eliminate the sound.
However, it's odd for such a noise to start up unless brake work was done recently. Is that the case?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 7 Old 03-24-2012, 03:55 PM Thread Starter
mreid10
No one has touched the brakes and all the mechanic did was the heim joint and sway bar bolt.
mreid10 is offline
post #4 of 7 Old 03-24-2012, 03:57 PM
Umbra0101
Thats usually the wear indicator, you most likely need breaks.
Last night, my girl started smoking, so I slowed down and lubed her up a little.
Umbra0101 is offline
post #5 of 7 Old 03-24-2012, 05:58 PM
N8N
eh, my F*rd pickup truck makes a noise just like that and I've been shafted by so many shops I've given up on it. (wanna buy a truck? Seriously, soon as I get the Jeep sorted, it's GONE. I have literally put more than the value of the truck into having people misdiagnose the problem and replace stuff that has nothing to do with the issue.) The ONLY thing related to the front end that isn't brand shiny new is the spindles themselves (well, and the I-beams, but they couldn't cause the noise I'm hearing.) So my amazing powers of deduction tell me that one or both of the spindles must have been worn by bad wheel bearings in the past to the point that the rotors wobble as they turn, causing that obnoxious noise.
So... question is, have you checked your hub assemblies for play?
N8N is offline
post #6 of 7 Old 03-24-2012, 07:03 PM Thread Starter
mreid10
Nah I literally got it back last night but that's a good start thanks.
mreid10 is offline
post #7 of 7 Old 03-27-2012, 06:44 PM Thread Starter
mreid10
Someone put the shield on incorrectly and it messed up my caliper, of course!
mreid10 is offline
taillight goes out when i press brakes Philistin85 XJ Cherokee Technical Forum 4 04-29-2009 01:43 PM
Squeaking and it's not the brakes houby67 XJ Cherokee Technical Forum 2 03-19-2008 08:30 AM
Squeaking noise when releasing brakes. cruz878 XJ Cherokee Technical Forum 5 05-23-2006 05:34 PM
Squealing/squeaking fan belt 97TJ2.5 XJ Cherokee Technical Forum 1 01-16-2003 02:27 PM
Squeaking/Squeeling noise in turns and Clunking/clicking noise when braking Sackdragger XJ Cherokee Technical Forum 3 05-14-2002 06:04 AM
