speedometer stopped working?! - JeepForum.com
post #1 of 8 Old 03-12-2006, 12:00 AM Thread Starter
cucr3
so i was driving home today when i looked down at my dash and saw i was going 0 mph...my speedometer just stopped working. is this a problem i can fix myself? i had some tranny work done a little while ago, could this be a result? thanks.
cucr3 is offline
post #2 of 8 Old 03-12-2006, 12:21 AM
kairo
kairo's Avatar
get under neath and look on the drivers side of the transfer case. there should be a little thingy stickin out of the top/left with wires coming out of it. Loosen the bolts holding it in, turn it as far as you can clock-wise, and then tighten the bolts back down (not too tight) See if that fixes it.
Some times that speedo gear will back itself off
Was: 1979 CJ-5, 1982 CJ-7, 1995 XJ, 1991 YJ, 2006 KJ, 1979 F-150
Is: 2011 Ram 1500 Hemi & '02 TJ on 35's
kairo is offline
post #3 of 8 Old 03-12-2006, 11:18 AM
Kuasimodem
Kuasimodem's Avatar
What year XJ?
1990 and older XJ's use a mechanical speedo with a drive cable running from the transfer case up.
1991 and newer XJ's use an electronic speedo with a sensor mounted on the transfer case, and the signal feeds to both the speedo in the dash and the computer (for shifting control).
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #4 of 8 Old 03-20-2006, 11:52 AM Thread Starter
cucr3
my check engine light also came on at the same time...could this be a result of the not working speedometer, and now the just noticed non-working odometer?
cucr3 is offline
post #5 of 8 Old 03-20-2006, 12:02 PM
TheRifleman
1989 XJ Cherokee
Suck it up. My Grand Wagoneers Speedometer hasn't worked since '95 and I drive it all the time.
Just kidding about sucking it up thought, I'd lookm to get it fixed asap...it becomes an annoyance when your dashboard start to not works...
TheRifleman is offline
post #6 of 8 Old 03-20-2006, 02:31 PM
conrasm
conrasm's Avatar
Definitely check the connection on the TC. It would also be worthwhile to pull the sensor out and inspect the speedo gear. If you recently had tranny work done, they may have chipped some teeth on the speedo gear. It's only plastic. If you can't find the problem and you think your actual speedo is broken, I have my old one from when I did the guage cluster swap. It has about 175K miles on it and worked fine, but there's no trip meter. (PM me if you or anyone else is interested-I have the complete guage assembly with idiot lights or if you just want the speedo). I would bet the speedo isn't getting a signal though.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #7 of 8 Old 03-20-2006, 03:13 PM
RT8827
RT8827's Avatar
so i was driving home today when i looked down at my dash and saw i was going 0 mph...my speedometer just stopped working. is this a problem i can fix myself? i had some tranny work done a little while ago, could this be a result? ... my check engine light also came on at the same time... thanks.
What year is your XJ? I'm guessing it's 1998-2000. When I bought my '99 a few weeks ago, I discovered the same problem. There's a recall for the airbag control module, and failure causes the symptoms you're describing. I had the recall service performed (for free) on my XJ, and I haven't had any problems since.
Check out this thread, where I included a link to the Jeep recall page. You can enter your VIN number there to verify that your XJ is eligible for the airbag recall (and any others for your vehicle).
Just like my Jeep hat says: "Life is good... do what you like, like what you do."
RT8827 is offline
post #8 of 8 Old 03-20-2006, 03:28 PM
oldblack93
Unhappy
When the speedo, oddometer, and gas guage stopped working on my '93, the problem was a broken ground wire on the side of the engine block.
oldblack93 is offline
Speedometer and odomiter stopped functioning ScottyG XJ Cherokee Technical Forum 4 04-01-2009 09:57 PM
Speedometer stopped working Khary23 XJ Cherokee Technical Forum 10 12-16-2008 06:54 PM
A/C Stopped Working Dannyboy18 XJ Cherokee Technical Forum 4 05-29-2008 09:28 PM
ABS stopped working jaardesign XJ Cherokee Technical Forum 6 12-15-2005 03:35 PM
87 Cherokee Speedometer stopped therealsmack XJ Cherokee Technical Forum 2 03-26-2005 11:34 AM
