Speedometer/Odometer Not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Speedometer/Odometer Not working
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 10-28-2009, 12:52 PM   #1
Goalie381
1998 FSJ Cherokee
I have a 1998 Cherokee Sport with the 4.0 I6, and the speedometer and odometer don't work, but the other gauges do. A mechanic said I need the complete gauge cluster replaced, but I'm wondering if it could be just a cable. Can anyone give me some insight?
Goalie381 is offline   Reply With Quote
Unread 10-28-2009, 01:01 PM   #2
jdearmitt
Check the ground wires on the passenger side of the engine block before you go and replace the gauges. There should be a stud with a nut on it right behind the distributor. Take the wires off, clean the contacts with some sand paper and brake cleaner. It's worth a shot.
-Justin
jdearmitt is offline   Reply With Quote
Unread 10-28-2009, 01:04 PM   #3
nrpalmer32
1987 XJ Cherokee
Also check the connections behind the gauge cluster, possibly it got disconnected
nrpalmer32 is offline   Reply With Quote
Unread 10-28-2009, 01:10 PM   #4
Goalie381
1998 FSJ Cherokee
I suppose I should've put this in the description but often forget. The speedometer works 1 out of a 100 times, and its always when I'm coming to a stop from faster than 25 mph.
Unread 10-28-2009, 01:14 PM   #5
jdearmitt
I would definitely check those grounds. Just fixed mine yesterday. Speedometer, odometer, and fuel gauge wouldn't work. They also caused some other problems.
-Justin
Unread 10-28-2009, 01:42 PM   #6
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
I fixed mine the other day by cleaning the grounds as well, but when I jumped in it the following day it didn't work again
Originally Posted by Trons View Post
I've only been a Jeep owner a few weeks, but I'm finding that a Jeep is a lot like a woman. They clean up nice, but they're more fun when they're dirty...
Condensed $300 Beater Build Thread - Updates Only - No Chit Chat
Original $300 Beater Build Thread - Please use this for comments
koolaid5 is offline   Reply With Quote
Unread 12-15-2009, 11:44 AM   #7
nick_n_ii
Could it also be a gauge cluster issue?
nick_n_ii is offline   Reply With Quote
Unread 12-15-2009, 12:06 PM   #8
lowicz96
1995 XJ Cherokee
Yes, My temp gauge quit working cause the plastic cracked around the mounting screws which was the connection between the cluster circuit and the gauge
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline   Reply With Quote
Unread 12-15-2009, 01:25 PM   #9
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Mine still isn't fixed. I replaced the gauge cluster, because I found a cheap one on ebay, but that didn't do anything. I took the ground off again and cleaned it all up, but still no luck. It has to be my VSS, or at least I'm hoping. I need to buy a replacement. Mine just doesn't look right the way all of that is going into the transfer case. Can someone snap a few pics of yours for me to compare?
Unread 12-15-2009, 01:38 PM   #10
nick_n_ii
Well my brothers 99 XJ so far:
I've replace the cluster, cleaned and inspected all the connections, cleaned the ground wire and added a second ground wire to be sure.
I'm at a lose.
Speedo and trip meter don't work and the Gas gauge reads full or empty randomly as you drive own the street.
Unread 12-15-2009, 02:04 PM   #11
lowicz96
1995 XJ Cherokee
Chrysler has never been known for their superb wiring
