speedo not working after SYE install - JeepForum.com
post #1 of 4 Old 01-21-2014, 05:21 PM Thread Starter
psychoteen101
Ive done a few SYE installs on NP231's and haven't had any issues. This last one I did and the speedo is not working. Used the OE gear on the speedo assembly. I installed it with the number range containing the gearís tooth count aimed down like explained in this write up http://jeepin.com/features/speedogear
Anybody have any other explanation for this issue? I confirmed that I plugged the speedo back in and I also pulled the assembly back out and made sure the gear didn't get eaten up from improper installation.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #2 of 4 Old 01-22-2014, 06:49 AM
M35A2
1995 XJ Cherokee
You remembered to put the drive gear on the shaft, correct? Try turning it 180, align the numbers with the other leg of the hold down. I think I did the same thing on one of the ones I did.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 4 Old 01-22-2014, 09:33 AM Thread Starter
psychoteen101
Yes, the plastic gear on the end of the SYE shaft that drives the speedo? Im gonna try to spin the speedo assembly a different way and see what happens. Just didn't want to install it wrong and have it mess the gear up. To my understanding, it wont be able to be installed all the way into the case before that happens.
post #4 of 4 Old 01-25-2014, 09:53 AM Thread Starter
psychoteen101
Spun it 180 degrees and got it to work. Appreciate the help
