Speaker Sizes? 2000 - JeepForum.com
post #1 of 18 Old 07-07-2007, 10:47 PM Thread Starter
jeepsurfgirls
Speaker Sizes? 2000
Hey
I got a 2000 Cherokee and instead of me poping off the door panels. I felt it would be easier to ask. I was wondering what size speakers do i have. Also anyone have any recommendations?
Thanks
"Your not Jeepin until you get stuck"
"Im not jeepin unless i break something"
jeepsurfgirls is offline
post #2 of 18 Old 07-07-2007, 10:52 PM
_Cody_
1993 XJ Cherokee
not sure if its the same as mine, but i think you might have a (2) 3.5" in the lower dash, and 5 1/4's in the doors/rear...might be wrong tho... just trying to help
and recommendations?
if you have money, Focal...the best thing i have ever heard, over mcintosh and others.
for low end, JL or memphis...kicker isnt bad either.
otherwise for mids and highs, Diamond Audio is great, along with memphis.
pioneer, kicker, RF, and a few others arent bad for the money.
2002 Trans Am WS6 ~Shop Car. 396ci, LS3 heads, Turbonetics 78mm, NX express, full 10pt cage...it's fast-ish.
2000 Grand Prix GTP ~Ported, Pullied, Heads, Cam, and all that jazz.
1996 XJ Sport. 4.0/A4 Daily Driver. 4.7 stroker and 3.5" lift in the works.
_Cody_ is offline
post #3 of 18 Old 07-07-2007, 10:58 PM Thread Starter
jeepsurfgirls
yeah that sounds like my 91 except for the dash ones.. ( didn't have)
but wondeirng if anyone can confirm this would also be the same size for 97+ ones
post #4 of 18 Old 07-07-2007, 11:00 PM
jeepinsane89
if its speakers and not subs, rockford is always good
2000 XJ Jeep Cherokee Sport 4x4 4.0 with 4.5" Rough Country Lift Kit with Front coil springs, front lower control arms, transfer case drop kit, front track bar drop bracket, swaybar links, brake line relocating brackets, 4 RC Hydro 8000 series shocks, and rear add-a-leafs, RC's Steering Stabilizer, 32" inch BF Goodrich All-Terrains, Cragar Soft 8's 15x8 rim, Flowmaster Super 40 Series Muffler with new 2.5" tubing all around, Stainless Steel Exhaust Tip, Set of Hella 500 Driving lights (on bumper), K & N Air Intake.
jeepinsane89 is offline
post #5 of 18 Old 07-07-2007, 11:17 PM
CKUPQ
Originally Posted by jeepsurfgirls
Hey
Thanks
Pop off one of your back speaker covers, it took me 5 seconds to pop one off and 10 minutes to take off a door panel. At the very least you'll get an idea of what you got becuase they should be the same.
Either our language or our culture needs to be expanded/improved so that there is a polite way to say:
Stop talking now, because I am going to stop listening.
99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear.
CKUPQ is offline
post #6 of 18 Old 07-07-2007, 11:20 PM
dudeinajp
dudeinajp's Avatar
Hey
Thanks
I have 6.5" all the way around. You have to watch the mounting depth on the front door speakers. 1 13/16" top mount depth, I believe.
CRUTCHFIELD
dudeinajp is offline
post #7 of 18 Old 07-07-2007, 11:51 PM
CKUPQ
I really wish when I had my 99 open I would have measured my openings. I did the same thing and put 6.5 pioneers in it, However I originally bought 5.25's and found out that some brands are too small.
Some pics that may help ya, these are the stock 5.25's
Both of these are 5.25's
CKUPQ is offline
post #8 of 18 Old 07-07-2007, 11:54 PM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
I put 5.25s in the rear. They are Polks and have tweeters built into the speakers. They are pretty slick.
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #9 of 18 Old 07-08-2007, 12:24 AM
SB6114
1987 MJ Comanche
i just recently put infinity components in the front and two-ways in the back, all are 6.5", stock the jeep comes with 5.25". if you are going to go with something component in the front i definately recommend mounting the tweeter in that little triangle on the door up by the side mirror. also, if you want descent sound out of the back, even with good speakers you will have to do a little reinforcing behind the headliner. I was able to accomplish this simply by buying a can of "great stuff", its a foam that comes in a can, you spray it out around the inside of the hole behind the headliner in the back and it will expand out and dry hard as a rock. you can cut it when it dries and maybe drill some portholes if you want. this more than doubled the bass out of the back because it kept my headliner from shaking so much, which kept my dome light from rattling. hope this helps!!! good luck!!!
SB6114 is offline
post #10 of 18 Old 07-08-2007, 08:05 AM
dudeinajp
dudeinajp's Avatar
I just used some poly fill from the crafts dept. at wally-world. It's cheaper and far less messy.
post #11 of 18 Old 07-08-2007, 09:36 AM
XJ2000
XJ2000's Avatar
SB is right, the stock measurements for the 2000 XJ are 5.25's all around. I'm also doing components in the front with the same setup as SB, using Polk Audio speakers front and back. They sound awesome.
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
post #12 of 18 Old 07-08-2007, 09:12 PM
monty1320
pop off a rear grille and measure. Crutchfield said my 2000 4dr had 5.25" all the way around. They were actually 6.5" So now I have 2 sets of Sony Xplode 5.25" 3-ways sitting in the garage, and nothing to put them in.
BTW I ended up getting the Infinity 6.5" -- good sound but not much bass. But, that's where the S12L7 kicker comes in.
2000 4dr XJ Sport
4.0, auto, NP231, 8.25 rear with No-Slip
3" springs, 2" spacers, bastard pack, 32X11.50 buckshot mudders,
Skid Row gas tank skid, Hidden Hitch, front tow hooks, Dual electric fans, No cat, no rear sway bar, JKS quicker disconnects, Tranny cooler, Hella H4 conversions with 90/130W bulbs, Hella 500FF lights (55W hid conversions), kicker S12L7 sub in cubby hole.
monty1320 is offline
post #13 of 18 Old 08-13-2007, 01:39 PM
worstplayer66
6.5"s will fit all around, you could put 5.25"s in the back but not in the front. I bout some 6.5" 4 way sony xplods from walmart for $50 and they sound great and will fit perfect in the front or back.
*edit - just wanted to add that I have a 2000 xj and I didn't have to drill any holes to install my 6.5's
worstplayer66 is offline
post #14 of 18 Old 08-13-2007, 03:03 PM
GRDCHRKE555
so wait... if 6.5'' speakers work ina 99 rather than 5.25's ... tiny.. ill just take my inifinitys out of my wj... definately not stock infinity's tho. is there any cuttting to fit the bigger speaker or does it just slide right in. and fro some reason the connections on my front speakers.. the stock ones.. are terrible! the driver side doesnt even work and the passenger side goes in and out depending on the size of the bumps in the road. and btw.. the drivers side doesnt work period. tried the passenger side speaker in it and same thing.
Kyle
99 XJ Classic, 4.0, AW4, 8.25 Rear
4.5" (~6'') RC lift w/ full leafs, RE 1.25" Shackles, Bilstein 5125's, IRO Custom HI-Clearance LA's,JKS quicker discos, C4x4 Front Hooks, TW's SYE/CV DS, FLO-PRO cat-back, and some 32'' x 11.50" Maxxis Bighorns
GRDCHRKE555 is offline
post #15 of 18 Old 08-13-2007, 03:30 PM
Cody_00_XJ
the drivers side wont work because their is a shot in the wire someplace between the speaker and the kick panel, i hav the same problem. i would make it a priority to run new speaker wire anyways if putting in new aftermarket speakers. and yes, 6.5's will for the most part "slide right in", as the only modification needed will be to screw new hole in, assuming that the speaker is not too deep. my infinity reference 6.5's fit in no problem in the front. im not sure for rear speakers though as i am only running 5.25's, but i have heard other say that they fit in without any issues
2013 JK Rubicon
Cody_00_XJ is offline
Speaker Sizes 99goldxj XJ Cherokee Technical Forum 24 07-20-2009 09:22 PM
speaker sizes Babazoo7 XJ Cherokee Technical Forum 4 10-03-2008 01:11 PM
2000 4dr speaker sizes Yfz450954x XJ Cherokee Technical Forum 3 08-03-2007 08:55 PM
speaker sizes in the xj omega1300 XJ Cherokee Technical Forum 1 07-08-2007 10:57 PM
Speaker sizes/removal 96_XJ_Country XJ Cherokee Technical Forum 15 09-23-2006 01:29 PM
