Spark Plugs - Champion vs. Autolite vs. NGK - JeepForum.com
post #1 of 11 Old 01-18-2010, 08:46 AM Thread Starter
Morris4x4Center
Morris 4x4 Center
Morris4x4Center's Avatar
1987 YJ Wrangler
I have searched and read too many threads to count. The only thing I have concluded is NOT to use E3, Splitfire, etc. I have even seen that the NGK V-Power is not liked as much the standard NGK.
First, I have a 1997 4.0L Automatic. I am using the Davis Unified Ignition Firepower Kit, performance coil, cap, rotor and wires. DUI recommends the Autolite AP985 (single platinum) gapped to .065". It is nearly impossible to gap these that much, so I settled on .050".
I had an issue that ended up being fuel related. In the process of diagnosing, I took it to a friend at the dealership. He frowned on the use of Autolite in a Jeep. He also said the AP985's were a little too short. At first glance, they do look slightly shorter than the Champion 412's. Once the seating rings are on, they both seem to have the same amount of thread left. The Champion's ring is much thicker. Once seated, I'm not sure how much difference there would be.
I have read that the stock 1997, 4.0L likes plain old copper plugs. But my ignition isn't stock.
I have read that Champions from the dealer are better than the ones from the local autoparts store, even with the same part number. I find this a little hard to believe. Differences of batches mabye, but a "better" plug???
I have also read that some dealerships are switching all their plugs (even for older Jeeps) to NGK because of quality issues with Champion. Even though, my friend has heard no such thing.
Are there any EDUCATED opinions about these plugs? What about platinum vs. plain copper?
I am most likely going to try a set of NGK 6779's (non-V-Power) next. With my ignition I will be trying .050" gap again. Unless someone can give me a better choice...
Jeep Parts and Jeep Accessories
Toll Free: 877.553.5337 | Free Shipping on Orders Over $75!
PM us for any questions.
Morris4x4Center is offline
post #2 of 11 Old 01-18-2010, 10:03 AM
XJH-007
XJH-007's Avatar
I've run everything from plain coppers, to splitfires, to 4 prong plantium truck plugs....... all in all they will all work.
I settled in on the 4 prong truck plugs. They seem to last a lot longer, have slightly better fuel econonmy, and the largest thing I noticed was a better Idle.
Bottom line, I don't think the 4.0 is a high enough performance motor to spend more then $5.00-6.00 per plug.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 11 Old 01-18-2010, 10:08 AM
mdywglr4x4
I would use copper. Copper is the best material for a spark plug in terms of performance. It will require a change more often but it is better. I know of big horsepower motors running on copper plugs because the performance is just better.
Just match to an NGK that is proper and will be the correct temp plug.
mdywglr4x4 is offline
post #4 of 11 Old 01-18-2010, 10:15 AM
crosschecker
1995 XJ Cherokee
Sure there are, write the manufacturers and ask them. Otherwise, this has been discussed many times on here and there are hundreds of educated opinions to choose from.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #5 of 11 Old 01-18-2010, 12:00 PM
BigD 275
Over the years I have tried alot of different plugs on my Jeep; from basic Champion, NGK, platinum, etc.
Currently have the E3 plugs and they work great. I must say that with the E3plugs, the engine does idle quite smoothly.
Overall, I never really noticed any significant difference from any of the plugs.
99 Jeep Cherokee Limited
BigD 275 is offline
post #6 of 11 Old 01-18-2010, 12:05 PM
Deezelweazel
I would like to know if those plus have more than one electrode and if someone tried indexing the plugs?
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline
post #7 of 11 Old 01-18-2010, 12:22 PM
XJH-007
XJH-007's Avatar
"those plugs"
Typically All plugs have ONE electrode (center) and just multiple variations on the grounding path. The multiple point plugs are not indexable.
***02 WJ Overland
XJH-007 is offline
post #8 of 11 Old 01-18-2010, 12:32 PM
Bain98xj
ive always heard and have experienced that jeeps dont run very well on anything but champion plugs
Bain98xj is offline
post #9 of 11 Old 01-18-2010, 01:04 PM
Mudviper
I also run E3 in mine and have not problems with it, but have also heard that Champion Truck plugs are prefered plug for the 4.0
Mudviper is offline
post #10 of 11 Old 01-18-2010, 01:08 PM
Deezelweazel
Originally Posted by XJH-007 View Post
"those plugs"
sorry, I was meaning the ground strap. And I know that indexing is not possible with muliple ground straps( does really make no sense)
post #11 of 11 Old 01-18-2010, 02:16 PM
olds442
olds442's Avatar
I use champion truck plugs...been running great for a while now
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
Champion vs Autolite SDH XJ Cherokee Technical Forum 62 12-16-2009 03:31 PM
Part number for OEM Champion Spark Plugs and Wires NYSLC93 XJ Cherokee Technical Forum 2 09-23-2009 09:54 AM
champion 438 spark plugs Brew461 XJ/MJ Cherokee Non-Technical Forum 1 07-12-2008 02:27 PM
who's using Autolite #3924 spark plugs BrunoS XJ Cherokee Technical Forum 3 09-25-2007 09:57 AM
Autolite plugs asheets934 XJ Cherokee Technical Forum 4 07-04-2006 10:29 AM
