Spark plug indexing - JeepForum.com
post #1 of 6 Old 10-13-2009, 03:33 PM Thread Starter
Diamond-x
1991 XJ Cherokee
Spark plug indexing
I don't want to start a discussion about 'which' spark plug to use, just how to.
So......
I saw on Powerblock TV where they indexed the plugs so the curved tip was open to the piston. They did this by removing the plug, marking where the electrode connected to the threaded end and made sure that the mark pointed straight up when re-installed. Theoretically, this would allow a better spark to ignite the cylinder. Without interference from the plug itself.
It's little tricks like this that racers have been using for years.
It's my thought that this would probably have a positive effect on ignition, granted minimal at best.
Your thoughts?
Diamond-x is offline
post #2 of 6 Old 10-13-2009, 03:35 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
not worth nearly the effort involved on a regular motor.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 6 Old 10-13-2009, 04:09 PM Thread Starter
Diamond-x
1991 XJ Cherokee
Well I do run a stroker, that might be worth some extra effort. and we do own Jeeps so we're used to wrenching on them.
post #4 of 6 Old 10-13-2009, 04:12 PM
leftlanetruckin
XJ on 37's
sorry, been there and done it.......3 frame off rebuilds on my last rig, along with motor swaps etc. now i just enjoy driving and wheeling them!
i still seriously doubt you will gain anything with indexing the plugs, but go ahead and try if it floats yer boat!
martin
post #5 of 6 Old 10-13-2009, 05:27 PM
Carves
Your thoughts?
Its not something I would bother with either, however ... "minimal" improvements and a few of them together can add up to major improvements in a situation ... which might be handy for those lookng foe a little bit more.
One of the plug companies was making plugs without the electrode and the core was recessed so there was a 360' arcing area ... no aligning nescessary.
Carves is offline
post #6 of 6 Old 10-13-2009, 08:17 PM
dacotua
1992 XJ Cherokee
I honestly believe indexing your plugs on a car with less than 500 horsepower is a waste of time. You won't even see 1 horsepower improvement. Its like the old K&N Filter ads... (Just install one of these and see up to 15 horsepower gain...) What they didn't tell you, is they stuck a paper filter on a engine that had over 500 horses, then the K&N, which on a highly modified motor, gained 15 horses.
dacotua is offline
spark plug tminter XJ Cherokee Technical Forum 6 01-31-2009 05:49 AM
best spark plug 99XJRider XJ Cherokee Technical Forum 48 11-12-2008 02:13 PM
Spark Plug Help dorsalfin3 XJ Cherokee Technical Forum 10 06-10-2008 11:21 PM
Spark Plug Gap dakotajeep XJ Cherokee Technical Forum 17 09-21-2007 06:53 PM
Spark plug gap? muddy bike XJ Cherokee Technical Forum 2 12-17-2004 03:25 PM
