Something wrong with Jeep's record of my vehicle - wrong build sheet - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Something wrong with Jeep's record of my vehicle - wrong build sheet
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREERough Country Jeep Suspension Deals at Rockridge 4WD!Bds fox ipf 2.0 racing series shocks now available at rock
Unread 12-19-2005, 04:26 PM   #1
prior2
Hey, I sent Jeep my VIN to get a build sheet on my XJ, and the sent me the wrong build sheet. I emailed them back about it, with the VIN directly off my jeep, and they maintain they sent me the right sheet.
The build sheet sent to me:
Thank you for your email to DaimlerChrysler Motors Corporation regarding
your 1987 Jeep Cherokee.
According to our records, your vehicle was equipped from the factory
with the following:
*A6 - Vinyl High Back Bucket Seats
-Y1 - No description found
ADA - Light Group
AGJ - Indy 500 Special Edition Group
APA - Monotone Paint
AWJ - Visibility Group
BCQ - 750 Amp Maintenance Free Battery
CAC - Low Back Bucket Seats
CGW - Next Generation Front Air Bags**
CGY - Drvr Inflatable Knee-Bolster Air Bag
CKA - Carpets - Floor and Cargo Area
CSA - Spare Tire Cover
CUF - Full Length Floor Console
DGQ - 5-Spd Automatic 545RFE Transmission
ERB - 3.XL Mid V6 Engine
GAC - Tinted Glass Windows
GEC - Front Left Side Sliding Window
GFA - Rear Window Defroster
GTZ - Manual Remote Mirrors
HAA - Air Conditioning
HCC - Heater
JAY - Instrument Cluster w/Tach
JGB - Digital Clock
JHA - Var Intermittent Windshield Wipers
JHB - Rear Window Wiper/Washer
LBB - Courtesy Lamps
LDA - Underhood Lamp
LMA - Halogen Headlamps
MD8 - Delete Front License Plate Bracket
NAA - Federal Emissions
NFA - 20 Gallon Fuel Tank
PE4 - No description found
QE4 - No description found
RAF - AM/FM Cassette Radio
SBA - Power Rack and Pinion Steering
SCE - 2-Spoke Soft Feel Steering Wheel
SUA - Tilt Steering Column
TBB - Full Size Spare Tire
TBL - Inside Mounted Spare Tire
WJN - 15" Aluminum Wheels
The corporate owner information database will be updated to reflect the
name/address change contained in your email. This will allow the
post-office to deliver DaimlerChrysler mail to your correct address.
Also, if your vehicle is involved in a future factory recall campaign,
you will be notified promptly by U.S. mail.
If I can be of any further assistance please let me know.
Again, thank you for your email.
Sincerely,
Susanna
Senior Staff Representative
DaimlerChrysler Customer Assistance Center
My Jeep has the 4.0L, and not the 3.xL V6 in the build sheet. Also, my Jeep does not have Airbags of any kind, or the 2 spoke soft feel steering wheel. My front license bracket is also still there, and the windows were not tinted when i purchased the vehicle. Can anyone help me with why Daimler-Chrysler may have sent me the wrong build sheet? Or is it possible my XJ was wrecked and had some parts replaced?
Also, what is the Indy 500 Special Edition Package?
prior2 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 04:29 PM   #2
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
A lot of the codes get reused. The code description has probably changed since the rig was built in '86.
Derpy Hooves for President in 2012
Matt Gertsch is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 04:33 PM   #3
BrunoS
something is whacked, bro.
call up the 1-800 customer care line and speak to someone personally.
somone has their wrong info.....check your vin id yourself, to see if it identifies the car as an xj, where it was built, etc...it's in the vin sequence. perhaps it's off a same model year chrysler, they used 3.0 v-6 mitsubishi motors in all front wheel drive product lines. next generation front airbags started like in 98 or so....as far as the indy 500, that sounds like the old dodge daytona series, the G-body, not the XJ....
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 04:45 PM   #4
ProjectXJRescue
There are several spots on your vehicle where their should be a VIN located at if I remember right from LEO classes. Theres the one on the windshield and then theres one or two others that are in hard to get spots. This is done to be able to identify a vehicle should the dash vin go missing or be filed down. Also it is possible that your vin on your car has been copied and used again on ur XJ. There is such a thing as vin theft, kinda like ID theft. Dont know its been done till u do a little digging or go to register the car. Is it possible your engine got swapped out? I mean yeah its weird that theres no match up with your Xj but theres lots of reasons why it might have happened.
Keith S. David
Moving to Loveland, Co in June
"Though Heaven Should Fall, Let Justice Be Done"
"People sleep peaceably in their beds at night, because of rough men who stand ready to commit violence on their behalf"
ProjectXJRescue is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 06:01 PM   #5
prior2
well, i checked all of the VINs on my Jeep, and they all match up...
Unread 12-19-2005, 06:06 PM   #6
LEAD_NOT_FOLLOW
1989 XJ Cherokee
I've heard that this is not uncommon from a few other Jeep guys.
Now as to why the build sheets are wrong is beyond me....
I've been "told" that it is due to the fact that the codes get re-used every 10 or so years. The database updates all files on record, thus updating your buildsheet with incorrect information.
LEAD_NOT_FOLLOW is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 06:08 PM   #7
mjd99xj
My XJ buid sheet came back kind of funky too, there were several options on it that werent actually there, tinted windows, fullsize matching spare w/ cover, and so on. Im of the opinion that they just arent reliable. Mines a 99 btw, so youd think itd be accurate
mjd99xj is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 08:22 PM   #8
mylt1
dude your jeep is almost 20 years old, before computers were an everyday item. as far as the 3.x if you do the math for ci-lit the 4.0 actualy comes out to 3.9 so yes its 3.x. mine was off to, but i didnt sweat it. some codes just changed and some stayed the same. most of the info there is probably correct other than some options.
mylt1 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2005, 03:15 PM   #9
fordtech
the jeep too old for the build sheet to be accurate.
fuel in my veins, mountains on the brain......
Current-06 Unlimited. Past- 98 XJ, 95 YJ, some Fords.
BUFFALO NY JEEPERS-http://www.wnyoffroad.org
http://www.cardomain.com/id/yjjeepinmike
Just your friendly neighborhood x-ford technician...
fordtech is offline   Reply With Quote Quick reply to this message
Unread 12-20-2005, 04:51 PM   #10
andrew2516
My 93' had a messed up build sheet also, it was saying I had a 3/4 XJ, and that I had the Corporate 8.25 rear, which I don't.
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
www.PGHOFFROAD.com
andrew2516 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2005, 05:47 PM   #11
conrasm
I found a build sheet for mine taped to the inside of the driver's door when I changed my speakers. It was a little weathered and faded, but still legible.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote Quick reply to this message
Unread 12-20-2005, 08:51 PM   #12
Matt Gertsch
www.lp.org
That's where I found mine.
Unread 12-21-2005, 12:38 AM   #13
lrsmithwhaley
1991 XJ Cherokee
According to my build sheet I have the Rubicon package.
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline   Reply With Quote Quick reply to this message
Unread 12-21-2005, 12:46 AM   #14
cmotsvt
I saw a build sheet on a Liberty CRD that said it had the high energy electronic ignition.
cmotsvt is offline   Reply With Quote Quick reply to this message
Unread 12-21-2005, 01:25 AM   #15
creature
Yeah, XJ's had a rubicon group way before the wrangler had their rubicon, too bad they got all the fun toys with theirs.
-Shawn
creature is offline   Reply With Quote Quick reply to this message
