Something rubbing every time I step on the brakes. - JeepForum.com
post #1 of 9 Old 12-22-2012, 05:21 PM Thread Starter
XJGuy07
1992 XJ Cherokee
So, I just put new tires and a lift on my jeep, and every time I step on the brakes something starts vibrating. I dont know whether its rubbing on the fenders or the brakes are all messed up. We had problems getting the brakes bled. Please Help!!!!
1994 xj dead and gone
1992 xj alive and awesome
XJGuy07 is offline
post #2 of 9 Old 12-23-2012, 04:59 AM
wgirvine
1992 XJ Cherokee
Hate to tell you this, but it ain't magic...
You think something is rubbing? Ok, jack up the Jeep, get a flashlight and start looking. Turn the tires, work the brakes, see what's going on. Take the tires and brake drums off, take a look. I can't see how air in the brake lines would cause a vibration. And bleeding brakes isn't tricky. If you had problems, you were doing it wrong. Figure out (read) how to do it correctly. Welcome to Auto Repair 101.
Oh, and don't step on the brakes while the drums are off!
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 9 Old 12-23-2012, 10:49 AM
tsc
Do you have ABS? could be the abs pump is going off if something is wrong with one of the sensors.
You also may have a front caliper hanging up
tsc is offline
post #4 of 9 Old 12-23-2012, 10:31 PM Thread Starter
XJGuy07
1992 XJ Cherokee
No, I don't think I do. It's a 92 Laredo. I'm starting to think it's the brake fluid because they haven't been bled properly. But that shouldn't make it vibrate could it?
XJGuy07 is offline
post #5 of 9 Old 12-24-2012, 01:28 PM
wgirvine
1992 XJ Cherokee
Air in the brake system will not cause vibrations. Can you describe the vibration? Do you feel it in the steering wheel? Brake pedal? Or the seat-of-your-pants?
wgirvine is offline
post #6 of 9 Old 12-24-2012, 11:14 PM Thread Starter
XJGuy07
1992 XJ Cherokee
It seems like it vibrates the brake pedal. What do you think it could be?
XJGuy07 is offline
post #7 of 9 Old 12-26-2012, 07:42 AM
wgirvine
1992 XJ Cherokee
If you are feeling a pulsing (feels like the brake pedal is rapidly moving up and down) most likely cause is out-of-round brake drums, or warped/uneven rotors.
wgirvine is offline
post #8 of 9 Old 12-26-2012, 11:02 AM
Hudson
I'd reccomend you buy "speed bleeder" for your jeep. They're a foolproof and easy way to bleed your brakes.
They cost about 20$ for two (40$ for your whole vehicle) and work wonders.
You unscrew your old bleeder valve and screw in this new one. It has a one way valve in it. Once it's in you crack it and pump the brakes. Air and fluid comes out and nothing goes back in. It's super fast and fool proof.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #9 of 9 Old 12-26-2012, 11:08 PM Thread Starter
XJGuy07
1992 XJ Cherokee
hmmm, I think i'll try that. Hopefully that will work. Where could I buy it?
XJGuy07 is offline
