Something to do with coolant system - JeepForum.com
post #1 of 4 Old 06-22-2013, 09:04 AM Thread Starter
LittleFoot89
1989 XJ Cherokee
I've been having this issue where if my heat inside is not on I leak coolant from this little cylinder right outside the firewall. I don't know what it is or if there's an easy fix rather than replacing the part. Summers comin up fast and it really sucks to have to have my heat on when its hot out. Any suggestions? What is that little can anyway?
89 jeep Cherokee Laredo
LittleFoot89 is offline
post #2 of 4 Old 06-22-2013, 10:09 AM
AZ Jeff
2014 JK Wrangler
Post a picture of "the little can", and we can help.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 4 Old 06-22-2013, 01:15 PM
sAe23
1995 XJ Cherokee
If it's the part with 4 hoses attached to it, that is the diverter valve for the heater.
If yours is plastic, it may be cracked (I looked at mine too hard one day and it fell apart!) or the hose clamps might be loose.
(I just googled it and an 89 should be metal...)
If the clamps are tight then just replace the part.
sAe23 is offline
post #4 of 4 Old 06-22-2013, 03:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Or, just eliminate it. No ill effects to doing so. Plug the vacuum line and connect the coolant/heater hoses rogether.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
