-   -   Something to do with coolant system (http://www.jeepforum.com/forum/f11/something-do-coolant-system-1539784/)
LittleFoot89 06-22-2013 09:04 AM
I've been having this issue where if my heat inside is not on I leak coolant from this little cylinder right outside the firewall. I don't know what it is or if there's an easy fix rather than replacing the part. Summers comin up fast and it really sucks to have to have my heat on when its hot out. Any suggestions? What is that little can anyway?
89 jeep Cherokee Laredo
AZ Jeff 06-22-2013 10:09 AM
Post a picture of "the little can", and we can help.
sAe23 06-22-2013 01:15 PM
If it's the part with 4 hoses attached to it, that is the diverter valve for the heater.
If yours is plastic, it may be cracked (I looked at mine too hard one day and it fell apart!) or the hose clamps might be loose.
(I just googled it and an 89 should be metal...)
If the clamps are tight then just replace the part.
cruiser54 06-22-2013 03:07 PM
Or, just eliminate it. No ill effects to doing so. Plug the vacuum line and connect the coolant/heater hoses rogether.
The time now is 02:08 AM.
