Someone must know where the relay is - JeepForum.com
post #1 of 21 Old 02-22-2008, 08:11 PM Thread Starter
john L. moore
can someone please point me to where I can find the headlight (highbeam/lowbeam)relay for my 1995 cherokee jeep. I went to a jeep dealer the first one said there was no relay in the 95 jeep that it was in the light switch it's not ...the second one looked it up in the book they will sell me a high/low beam relay for $10.00 (part number 4727370aa)but they and their mechanics have no Ideal where it is located in the car. I've check chilton at the local books store and they do not list where to find it
Last edited by john L. moore; 02-22-2008 at 09:03 PM. Reason: added highbeam a lowbeam because of the 10:16 Post
john L. moore is offline
post #2 of 21 Old 02-22-2008, 08:16 PM
tangofox007
Unless the vehicle has been modified, the headlights are powered through the switch. There is no relay.
tangofox007 is offline
post #3 of 21 Old 02-22-2008, 08:18 PM
Viscerebral
1990 XJ Cherokee
^x2 10char
Bad things happen to you because you are a dumb***.
88 XJ (sold to fund Frankenjeep->), 90 XJ (Frankenjeep, a DD built from the carcasses of 3 other less worthy XJs), 98 ZJ (Wifes DD)
Colorado Jeep Club Member #836
Viscerebral is offline
post #4 of 21 Old 02-22-2008, 11:30 PM
cheapfix
1991 XJ Cherokee
If you are looking for the switch that kicks from hi to lo beam, I can tell you where it is on my '91, I believe your '95 uses the same interior and switches, etc. Someone jump in if I am mistaken:
It's about halfway down the steering column on the left side, held on by the same bolts that hold the ignition switch. It is operated from the multi-switch (turn, wiper, hi/lo beam, cruise) handle by a short rod running down the column.
Take off the bottom full-width panel of fthe dash (six or eight screws, including one behind the ashtray), and it is easier to see and get at. One nut should have it loose, unplug the connector, and head to the wrecker or parts store. Try asking for a high beam switch rather than relay.
Recovering moparholic
cheapfix is offline
post #5 of 21 Old 02-23-2008, 07:49 AM
tangofox007
John,
It is often easier to obtain useful information if you describe the symptoms of the problem you are attempting to solve, rather than presenting a diagnosis that involves the replacement of nonexistant components. (For example, the switch mentioned above is known to get out of adjustment. Simply readjusting it could solve your problem.)
What is it, exactly, that is not working correctly?
post #6 of 21 Old 02-23-2008, 11:32 AM Thread Starter
john L. moore
tangofox..
I've have explained the problem in previous post and seem to get the same answers that is why I asked 'just where to find the relay' 7 months ago our jeep high beam stopped working low beans did light up..I posted the problem and received help as to replace bulbs even though I explained that was the first thing I checked. now about two months ago the both h/l beams stopped working. I again posted 4 help..hoping someone could give me a clue as the next step I should take..I then received replies 'its the headlight switch' and another saying it was the 'switch on the steering column along with the directional's (one unit)..I then went and purchased a new head light switch and it didn't help, I then instead of purchasing the switch assembly for the steering column I switched it with a neighbor that has the same vehicle and again it did not help. I could not find anything that you could adjust that went from the steering column to behind the plastic covers ether I miss understand or its just this year is not the same as the older 91's. my unit comes off with two screws and unplug the harness. Now why the relay..I've been told by the jeep dealer there is a relay that is in line with the switch on the steering column that when you pull on the high beam switch it activates a relay that should power the high beams they will sell me the relay they just can't tell me where it is located..My other thoughts of why it would be some sort of relay is because both lights our now out, but when I put a probe on the connector plug of one of the headlights there is power but the negative plug is also showing power another words all three wires are hot and there is no ground going to the bulbs, In the days back I owned a couple of foreign cars where the relay for the head light in fact would just produce a ground when you hit the switch..I might be way off mark but I do know if a relay is stuck or moister gets in it you do get erratic functions. also the back lights / taillights etc..all are working correctly the high beam indicator in the dash works as normal.. I'm very thankful for a forum like this and I hope I'm not sounding condescending I realize it is almost impossible with electrical problems to diagnose ..over the internet. but I've been told so many different stories 1) the relay is in the light switch in the dashboard. 2) it is located behind the steering column 3) it is on the left side of the radiator in the front of the car 4) there is no relay , 5) there is a relay 6) its on the steering column. Also the wiring schematic that comes from mitchel auto repairs shows it next to the radiator which I can not find. but again it says there is a relay..also we had the car since 1996 and it has never been a problem and no one has ever done any wiring changes. thank you very much for all the info that all the people have offered, I will keep trying and hope someone with the same 1995 cherokee had the same problem and found the solution.
post #7 of 21 Old 02-23-2008, 11:36 AM
Rescue XJ
Originally Posted by john L. moore View Post
tangofox..
Im sorry about your beans.
I cant remember who I was sleeping with 7 months ago, so how can anyone remember a post about headlights from that long ago?
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #8 of 21 Old 02-23-2008, 11:43 AM
Crystalship1
Crystalship1's Avatar
That's a multi purpose relay but looks like it has nothing to do with headlights. This reinforces MY belief that there is NO headlight relay. Looky here (from a Mopar parts dealer look-up):
Item Number
MSRP
Core Price
Price
4727370aa
$9.70
$0.00
$6.38
Electrical - Chassis electrical - Horn - Horn relay
HORN RELAY, Jeep 1994 - 2000
4727370aa
$9.70
$0.00
$6.38
HORN RELAY, Jeep, XJ Series 2001
4727370aa
$9.70
$0.00
$6.38
Starter - Relay
RELAY, Jeep - 2.5L 1994 - 2002
4727370aa
$9.70
$0.00
$6.38
Starter - Relay
RELAY, Jeep - 4.0L 1994 - 2004
4727370aa
$9.70
$0.00
$6.38
Fuel system - Fuel supply - Fuel pump relay
FUEL PUMP RELAY, Jeep 1994 - 2002
4727370aa
$9.70
$0.00
$6.38
Electrical - Powertrain control - Oxygen sensor relay
OXYGEN SENSOR RELAY, All Models 1994 - 1998
4727370aa
$9.70
$0.00
$6.38
Electrical - Chassis electrical - Fog lamps - Relay
RELAY, All Models 1993 - 1998
4727370aa
$9.70
$0.00
$6.38
Electrical - Body electrical - Illuminated entry - Relay
4727370aa
$9.70
$0.00
$6.38
Starter - Relay
4727370aa
$9.70
$0.00
$6.38
FUEL PUMP RELAY, All Models 1993 - 1998
4727370aa
$9.70
$0.00
$6.38
Hvac - Controls - Blower motor - Resistor
RESISTOR, All Models, w/ATC 1997 - 1998
4727370aa
$9.70
$0.00
$6.38
Brakes - Anti-lock brakes - Pump motor relay
PUMP MOTOR RELAY, All Models 1997 - 1998
Add to Cart Contact Us
Collision Catalog
Item Number
MSRP
Core Price
Price
4727370aa
$9.70
$0.00
$6.38
Electrical - Starter - Relay
Relay 1997 - 2001
4727370aa
$9.70
$0.00
$6.38
Electrical - Horn - Relay
Relay 1997 - 2001
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #9 of 21 Old 02-23-2008, 11:57 AM Thread Starter
john L. moore
008 electrical 510 relays cherokee...: Pos 3, Relay , Headlamp & dash wiring Partnumber 0638094 .also 13 Relay headlamp delay partnumber #56000636 this is from the jeep dealer who wants to sell me a relay.
post #10 of 21 Old 02-23-2008, 12:05 PM
motorheadmach1
1990 XJ Cherokee
my old mj used to do many of the same things, one day the lights would work the next they wouldnt. no high beams, than all if asudden tehy just stopped working etc. i replaced the switch, the relay, the bulbs, and eerything else that seemed to be part of the system. one day an guy that works at a jeep dealer told me to check all the different wiring harness plugs under the hood, specificly by the firewall he thought one of the had something to do with the lights. sure enough there was a plug i want to say it had 6 wires going into it that made teh lights comeone when i wiggled it. turns ut when i cleaned it p the housing of the plug was cracked and the wies got loose not to mention dirt, mud, rain, oil, and grease. i cleaned it all up and taped it up good and water tight and with copious amounts of dielectric grease i neer had a problem with it again. i dont know if its the same on yours or not but it could be worth looking for.
1990 XJ, complete HO swap, approx 4" lift, 33 mt's, "trimmed" fenders, cobra CB, Homebrew roof light bar, 91' non disconnect front axle. various odds and ends.
"Friends don't let friends wrench alone"
motorheadmach1 is offline
post #11 of 21 Old 02-23-2008, 03:40 PM
Stumedic
John, someone else has a similar problem that you do. His problem turned out to be a faulty ground. Here's the link. Stu
http://www.automotiveforums.com/t878..._location.html
Stumedic is offline
post #12 of 21 Old 02-23-2008, 06:16 PM
Crystalship1
OK... 0638094 comes up "part number not found" and the second (or should I say third) part number shows it being a "Headlamp Delay Module". See below:
Item Number MSRP Core Price Price
56009324 $52.25 $0.00 $34.49
MODULE HEADLAMP DELA
Part number 56000636 was superseded by part number 56009324.
Good Luck!!
post #13 of 21 Old 02-26-2008, 09:51 AM Thread Starter
john L. moore
reading systm wire diagrams
I'm back trying to locate the headlight problem. I took a ground wire and attached it to the ground wire at the headlight plug...wow when I turn on my light switch the lights work. so now I'm following the black ground wire from the headlight lamp towards the on / off switch thinking somewhere along the line there is a relay or bad connection. my wiring diagram shows it going to the 'headlight delay module) says it is 'left side of i/p' does anyone have any idea what 'i/p' stands for?..or where I find the delay module
thanks for all the help jlm
post #14 of 21 Old 02-26-2008, 10:07 AM
jeeptown
I/P = instrament panel
jeeptown is offline
post #15 of 21 Old 02-26-2008, 07:05 PM
Stumedic
John, The headlights should connect to chassis ground G106 through a plug C106. G106 is located somewhere on the drivers side chassis or fenderwell. I don't think it's important to find the break in the ground wire. Just run a new one. Stu
Stumedic is offline
fan relay groundzero XJ Cherokee Technical Forum 12 05-31-2008 06:26 AM
relay help h2omonkey XJ Cherokee Technical Forum 0 02-02-2008 02:18 PM
Fan Relay dajeepman XJ Cherokee Technical Forum 5 02-19-2007 08:34 PM
Why a fuel pump relay output on my A/C Relay twisted_ed XJ Cherokee Technical Forum 0 04-02-2005 02:11 PM
Do I need a relay? w^rl0rd XJ Cherokee Technical Forum 8 03-22-2005 07:19 PM
