So my jeep doesn't exist! - JeepForum.com
post #1 of 5 Old 10-17-2013, 05:59 PM Thread Starter
84xjwagoneer
1984 XJ Cherokee
Hi all,
So finished lifting the 84 wagoneer, Took it to the mechanics last week to replace my ratcheting D30 w/disco CV shafts (which I understand is an anomaly), an alignment, and other minor stuff. So minor stuff was fixed, get a call Monday.
Apparently he can't find replacement shafts for my axle. Car quest and other shops kept sending him either non disco shafts or disco shafts that are 27 splines and a smaller diameter as opposed to the originals (29 spline). So we decide to send out the originals to get rebuilt, at a significant cost compared to buying shafts(65 for a shaft and 110 to rebuild each). So I get a call today, they can't find parts to fix the joint.....
So I call jeep customer service as a last ditch effort, they refer me to three vendors, all of whom insisted that XJs didn't exist before 86 .....
What the hell do I do ! I'm dead in the water without my daily driver.
I'm almost 100 percent sure I don't have RCVs, CLARiFYiNG IT IS AN XJ Not a grand wagoneer.
Just to make sure heres a pic of the axle
84xjwagoneer is offline
post #2 of 5 Old 10-17-2013, 06:31 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Go to RockAuto.com. Find the parts you need by brand name, and part number. Have the idiots at the auto parts store order by brand name and part number the shafts you need, not by make/model/year of vehicle.
XJ D-30 U-joint shafts and CV shafts are interchangeable, why not use u-joint axle shafts ?
I have never owned an early XJ with the Vacuum Disconnect, are you sure the axle spline count varies, early vs. later ?
29 spline vs 27 spline normally refers to Transfers Case and transmission input/output shafts.
According to RockAuto, all 1984-1989 XJ D-30 use the same part numbers for CV axle shafts.
CJ7-Tim is offline
post #3 of 5 Old 10-18-2013, 11:09 AM Thread Starter
84xjwagoneer
1984 XJ Cherokee
Ok so correction, 2 of the splines on the shaft we counted had notches so I counted two extra, the shaft is 27 spline but is still a larger diameter then any shaft we can find. All shafts that we've been using just spin in place and grind against the slots for the larger diameter splines
post #4 of 5 Old 10-18-2013, 01:07 PM
Azzy
another option... Get another D30 from a JY XJ, like an HP, and forget it? They swap in quick.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 5 Old 10-18-2013, 01:21 PM
CherokeeBen
1984 XJ Cherokee
On my 84 I switched out the cv shafts with ujoint shafts from a later model xj no problem.
CherokeeBen is offline
