So I removed my oil cap to find this... - JeepForum.com
post #1 of 76 Old 08-28-2010, 02:24 PM Thread Starter
alexrule123
alexrule123's Avatar
Looks likes coolant is getting into the oil , can anyone else confirm this for me?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #2 of 76 Old 08-28-2010, 02:31 PM
danw77
1994 ZJ
yup, that's what it looks like to me. if you drain your oil and let it sit it, the water/coolant should separate from the oil. it wouldn't hurt to fill it up with fresh oil and see if it happens again, but my bet is a cracked head and/or blown head gasket.
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
post #3 of 76 Old 08-28-2010, 02:34 PM
Timo_90xj
Timo_90xj's Avatar
Have you noticed if you are loosing coolant, or if there is oil in your coolant? I'd check those first and also check compression on each cylinder. You do have an obvious sign of coolant in your oil, but it's not necessarily that.
I've had water condensate to the oil cap a number of times due to weather changes (ie. hot to cold, humidity) or frequent short-term use where the engine warms and then cools down, warms up again..
edit: I noticed you're from Florida, so water condensation can quite certainly be ruled out.
***Under construction***
Timo_90xj is offline
post #4 of 76 Old 08-28-2010, 02:37 PM Thread Starter
alexrule123
Well I just changed the oil last weekend and yes I am loosing coolant so that basically confirms a cracked head
edit: I have access to several cylinder heads, one is off of a 95 sitting in my garage and the one from my 99
post #5 of 76 Old 08-28-2010, 02:39 PM
Timo_90xj
Timo_90xj's Avatar
In that case, yes. I see you have an '01 so a cracked head wouldn't surprise me.
post #6 of 76 Old 08-28-2010, 07:07 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Doesn't sound good. The 2001 XJ has the infamous 0331 head, which has a history of cracking.
I would pull the valve cover and look very carefully between cylinders 3-4 (where the casting defect is). A good many people have actually verified and seen the crack(s) in this manner.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 76 Old 08-28-2010, 07:13 PM Thread Starter
alexrule123
Well I finished pulling the head off of my '99 so I am just going to swap it over since it is a 0630 cast number.
post #8 of 76 Old 08-28-2010, 09:31 PM
Rescue XJ
Yeah I was going to point out the 01/0331. . I wish I had several heads in MY garage. . .
Dont pour bacon grease into your jeep, it is not an engine lubricant, no matter how good it makes your jeep smell.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #9 of 76 Old 08-28-2010, 10:05 PM
basso4735
basso4735's Avatar
1997 XJ Cherokee
Wow, now I know exactly what I don't want to see on my oil cap.
Good luck.
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
post #10 of 76 Old 08-28-2010, 10:41 PM
robsjeepxj
It would be a good idea to throw in some new lifters to while you have the head off. They're cheap and are another of the jeeps notorious weak points.
robsjeepxj is offline
post #11 of 76 Old 08-28-2010, 10:43 PM
robsjeepxj
Yuck, that's nasty. It would be a good idea to throw in some new lifters to while you have the head off. They're cheap and are another of the jeeps notorious weak points. Flush out the oil and coolant as well a FEW times especially the oil before you drive it too much.
post #12 of 76 Old 08-29-2010, 09:02 AM
4jeepers
Water for sure. You know the drill! Good Luck
4jeepers is offline
post #13 of 76 Old 08-29-2010, 09:09 AM Thread Starter
alexrule123
I'll try not to sneeze into the oil next time, I promise!
Well I do happen to have a cam that has been laying around for some time, maybe I should just install that puppy in there as well.
post #14 of 76 Old 08-29-2010, 10:33 AM
irs009
Howdy Alex, As you can see, I have an 01 too. Did you overheat the vehicle, or do you know if you did anything out of ordinary. I'm well aware of this flaw, but would like to hear some people analyze what caused it...Thanks
irs009 is offline
post #15 of 76 Old 08-29-2010, 11:04 AM
Crunch
I dont think the '99 head will work... I have read that you will have to switch exhaust, header,computer and wiring.. The '00-'01 have 4 02 sensors...
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering
Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift.
SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it!
Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff.
Crunch is offline
to those who have removed the carpet kjf45 XJ Cherokee Technical Forum 11 08-07-2009 09:56 AM
For those of you that have removed your carpet... ki1022 XJ Cherokee Technical Forum 1 08-23-2007 02:14 PM
Has removed EGR cought up with me..... LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 6 04-29-2006 06:45 PM
Anyone who's removed their headliner please help XJ-NoDough XJ Cherokee Technical Forum 7 05-23-2005 10:13 PM
Who has removed or gutted their cat? LOCKED UP XJ Cherokee Technical Forum 2 07-05-2004 10:18 PM
