So the electric fan works... - JeepForum.com
post #1 of 3 Old 11-23-2010, 05:05 PM Thread Starter
D0dgeRam1500
Today I finally had time to work on the Jeep. I hooked the electric fan directly to the battery and it works but it won't kick on when the A/C is on or when the Jeep starts to run hot (well hotter than a Jeep should). So which sensor do I need to replace? Or is it a wire? Or is it a bad thermostat?
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #2 of 3 Old 11-23-2010, 05:45 PM
JKM3134
1983 CJ7
there is a sensor in the radiator just below one of the transmission cooler lines.
the harness connector is on the front driverside fenderwell in front of the air cleaner.
but i think the fan should turn on with the ac even without this sensor operating correctly.
you may have another problem. is there a fan relay?
JKM3134 is offline
post #3 of 3 Old 11-23-2010, 06:43 PM
tangofox007
I would suggest that the fan relay is the prime suspect.
tangofox007 is offline
4x4 , cherokee , jeep , limited , xj
Sometimes works, sometimes not? E-Dubs88XJ XJ Cherokee Technical Forum 3 10-01-2008 09:28 PM
How this works StokedXJ11 XJ Cherokee Technical Forum 1 04-03-2007 10:53 AM
Fix: electric window failure. Only the drivers control works for non-driver windows Mass Cherokee XJ Cherokee Technical Forum 9 11-08-2006 08:29 AM
Electric Window/left speaker not working/works InDurango XJ Cherokee Technical Forum 0 09-15-2006 01:56 PM
electric fan manually works, but will never auto. turn on...? jugger XJ Cherokee Technical Forum 4 03-22-2005 07:17 PM
