So can I remove and replace the Header Panel myself? - JeepForum.com
post #1 of 7 Old 01-10-2007, 03:58 PM Thread Starter
Lution
I'm looking at getting a new front nose (header panel) for my 99 Cherokee. The current one is cracked so I'm buying an aftermarket nose online and getting it painted. The body shop charges a bunch to replace it.
So can I do this myself? Will it be a bad time?
99' XJ Sport
Lution is offline
post #2 of 7 Old 01-10-2007, 04:10 PM
XJ's4-ALL
I recently took it off so i could access my fender bolts. It was really easy just becareful when you pull you headlight harness out they are not forgiving.
XJ's4-ALL is offline
post #3 of 7 Old 01-10-2007, 06:14 PM
ebk04
go ahead and do it yourself. I just had one in the shop a couple weeks ago that I put a whole front end on. If I remember correctly take out the park lamps, headlight bezels, headlights, grille, two 10mm nuts by the headlights that hold the bottom of the panel, then theres about 8, 10mm bolts above the top of the radiator support that hold the top and she should come off, reverse to reinstall.
1997 Jeep Cherokee Country, 3" Rough Country lift, 31" BFG ATs on 15x8 Outlaw IIs, Dynomax, uniden cb, 8"jbl cubby hole sub
ebk04 is offline
post #4 of 7 Old 01-10-2007, 06:17 PM
98tXJ
ebk is right. It really is easy
98tXJ is offline
post #5 of 7 Old 01-10-2007, 11:27 PM Thread Starter
Lution
thanks very much!
99' XJ Sport
Lution is offline
post #6 of 7 Old 01-11-2007, 12:00 AM
Hellkat241
Hate to Hi-jack (seems ? is resolved). Can you mount off-road lights to this nose piece (grill). Or is the plastic(?) just to weak? I just finished installing my JCR bumper(pics FRIDAY ) and i can't see myself drill into this 1/4" steel. I just bought Walmart lights and would still like to use them with the new bumper...Thanks in advance..Mike
2000 dark blue cherokee classic
tiny BFG All Terrians and all stock
Hellkat241 is offline
post #7 of 7 Old 01-11-2007, 03:57 PM
JohnnyBling
I wouldn't mount headlights to it. Hit bumper with punch. Put bit on mark. Drill the bumper. Start with a small bit and work your way up to the size you need.
JohnnyBling is offline
So I had to replace my header panel, want to reinstall the jeep logo willcherokeexj XJ Cherokee Technical Forum 4 07-10-2009 11:50 AM
will the header panel from a 88 2-dr fit a 96 4-dr? Rubicon304 XJ Cherokee Technical Forum 1 02-18-2009 11:17 PM
How do I remove the metal molding between my grill and my header panel? The Lure Washer XJ Cherokee Technical Forum 3 02-02-2009 05:49 AM
Need New Header Panel louisd11 XJ Cherokee Technical Forum 11 11-24-2007 11:56 AM
Header Panel BajaFire XJ Cherokee Technical Forum 2 09-19-2006 08:17 PM
