Snorkel install - JeepForum.com
post #1 of 16 Old 04-19-2017, 10:29 AM Thread Starter
96xjinprogress
Snorkel install
Anyone have a good write up on snorkel install
Sent from my iPhone using Tapatalk
96xjinprogress is offline
post #2 of 16 Old 04-19-2017, 11:26 AM
RedJeepster1
Low and Slow
RedJeepster1's Avatar
If you buy a snorkel it should come with instructions on how to install it.
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Red XJ w/ 350k+, AW4, NP231, Locked Rear, HD Crown Leafs, trimmed to fit 33's, soon to be a donor
2000 Silver XJ, Drivetrain from the Red XJ, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's <=== In the works
RedJeepster1 is online now
post #3 of 16 Old 04-19-2017, 01:09 PM Thread Starter
96xjinprogress
Well I haven't bought one yet. But I have a chrome intake right now I just wonder if the will hook up to it
post #4 of 16 Old 04-20-2017, 07:39 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Does it look like this?
D3<!L!>3D
S8NNG8 is offline
post #5 of 16 Old 04-20-2017, 03:14 PM Thread Starter
96xjinprogress
No it's just a chrome pipe with a cone filter.
post #6 of 16 Old 04-20-2017, 03:18 PM Thread Starter
96xjinprogress
If I hooked it to the intake I have wouldn't I have to do away with the filter. Bc I really don't wanna do that, that's just a disaster waiting to happen
post #7 of 16 Old 04-20-2017, 04:44 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Just follow this design. The filter is in the fat part at the middle.
D3<!L!>3D
S8NNG8 is offline
post #8 of 16 Old 04-20-2017, 05:03 PM Thread Starter
96xjinprogress
O I c. So I can get one of those and just run the snorkel to it. Where can I find one of these
post #9 of 16 Old 04-20-2017, 08:48 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
This is a cowl snorkel. It goes through the firewall and breathes through the vent by the wipers. Imo, thats all the snorkel a logical driver should need. You get into water past that point and you got bigger problems anyways.
This is the Spectre cowl intake specifically designed for the XJ. ~$200 at O'reilly's and it comes with the filter.
D3<!L!>3D
S8NNG8 is offline
post #10 of 16 Old 04-21-2017, 10:47 AM
SmashDN
I like XJ's. But don't bring an XJ to do the job of a boat.
SmashDN is offline
post #11 of 16 Old 04-21-2017, 01:25 PM Thread Starter
96xjinprogress
I jut want a snorkel for looks I would never go into water deeper than the jeep can handle lol if I was gonna do that I would just go swimming
post #12 of 16 Old 04-21-2017, 03:06 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
In that case, I'd still recommend the Specte. Then just buy the exterior snorkel piece and put it on for looks. Or custom design one that wouldnt normally be possible due to plumbing constraints.
D3<!L!>3D
S8NNG8 is offline
post #13 of 16 Old 04-22-2017, 07:27 PM Thread Starter
96xjinprogress
I heard about this cowl snorkel. I have tried to look it up from spectre and can't find anything.
post #14 of 16 Old 04-22-2017, 09:20 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
https://autoplicity.com/3672703-spec...OY_hoCzmHw_wcB
D3<!L!>3D
S8NNG8 is offline
post #15 of 16 Old 04-23-2017, 12:08 PM
un4gvn1
un4gvn1's Avatar
1988 XJ Cherokee
After researching snorkels I went with the Airflow. Aussie made (better plastic than the Chinese knockoffs), quite a bit cheaper than the ARB (Safari).
http://www.airflowsnorkels.com/details.php?id=19
In order to go this route you'll need a OE airbox & intake hose (from filter to throttle body). These should be cheap at your local Pick&Pull.
The snorkel came with detailed instructions & a full-size template so you only cut one hole in your fender. Be aware this snorkel goes into the rear of the airbox, you make a block-off plate for the OE intake opening. You will need to move or replace your windshield washer bottle.
As for looks, you be the judge.
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
un4gvn1 is offline
