snorkel 4.0 motor - JeepForum.com
post #1 of 8 Old 05-19-2013, 11:52 PM Thread Starter
MS_Xj
snorkel 4.0 motor
What all have y'all used for making a custom snorkel for yalls xj's? I've seen flex pipe and PVC but what size is the best for airflow? Also where should I relocate the ecm?
MS_Xj is offline
post #2 of 8 Old 05-20-2013, 07:55 AM
austin6137
1990 XJ Cherokee
Not being rude here but search its been covered alot, but me personally I used a cheap eBay knock off. My computer is under the dash so I dont plan to sink it that far lol.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #3 of 8 Old 05-27-2013, 04:31 PM
JPCherokee
If you want to look into alternatives to a snorkel a lot of guys run their intakes in the cowl (under the vents between the hood and windshield). check out http://http://ericsxj.com it is under tech write-ups. this will eliminate a silly pvc snorkel and raise the height of your intake. Good luck with whichever route you end up going!
JPCherokee is offline
post #4 of 8 Old 05-27-2013, 05:06 PM
mschi772
1997 XJ Cherokee
Not only should you search because repeat threads are tiresome, you should search because you'll get WAY more different versions/ideas/methods through a search than will ever respond to this thread.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #5 of 8 Old 05-30-2013, 07:52 PM
holysirsalad
Yes. There are writeups on this very subject!
holysirsalad is offline
post #6 of 8 Old 06-03-2013, 02:46 PM
sAe23
1995 XJ Cherokee
Originally Posted by MS_Xj View Post
[snip]
What year is your Jeep? (Fill out your profile or provide details in your posts!)
Unless you are thinking of moving it a distance within the constraints of the wiring harness, are you really prepared for a massive re-wiring job?
sAe23 is offline
post #7 of 8 Old 06-05-2013, 10:51 PM
cdn_xj
I've returned to the fold
cdn_xj's Avatar
What? you mean someone else has asked this question before?
'99 XJ Sport 4-dr
4.0 HO - AW4 - NP231 - D30, 4.10, Open - ChrysCo 8.25 29-Spline, 4.10, OEM Trac-Loc
Stock with a crapload of bolted on bits
cdn_xj is offline
post #8 of 8 Old 06-06-2013, 01:47 PM
Jeep_Tech
i used a drainage pipe from lowes and 3 rolls of duck tape. and about half a roll of bailing wire..............It works great with my 2x4 lift kit
Jeep_Tech is offline
