-   -   snorkel 4.0 motor (http://www.jeepforum.com/forum/f11/snorkel-4-0-motor-1525717/)
MS_Xj 05-20-2013 12:52 AM
snorkel 4.0 motor
What all have y'all used for making a custom snorkel for yalls xj's? I've seen flex pipe and PVC but what size is the best for airflow? Also where should I relocate the ecm?
austin6137 05-20-2013 08:55 AM
Not being rude here but search its been covered alot, but me personally I used a cheap eBay knock off. My computer is under the dash so I dont plan to sink it that far lol.
JPCherokee 05-27-2013 05:31 PM
If you want to look into alternatives to a snorkel a lot of guys run their intakes in the cowl (under the vents between the hood and windshield). check out http://http://ericsxj.com it is under tech write-ups. this will eliminate a silly pvc snorkel and raise the height of your intake. Good luck with whichever route you end up going!
mschi772 05-27-2013 06:06 PM
65 Attachment(s)
Not only should you search because repeat threads are tiresome, you should search because you'll get WAY more different versions/ideas/methods through a search than will ever respond to this thread.
holysirsalad 05-30-2013 08:52 PM
Yes. There are writeups on this very subject!
sAe23 06-03-2013 03:46 PM
Originally Posted by MS_Xj (Post 15455001)
[snip]
What year is your Jeep? (Fill out your profile or provide details in your posts!)
Unless you are thinking of moving it a distance within the constraints of the wiring harness, are you really prepared for a massive re-wiring job?
cdn_xj 06-05-2013 11:51 PM
What? you mean someone else has asked this question before? :laugh:
Jeep_Tech 06-06-2013 02:47 PM
i used a drainage pipe from lowes and 3 rolls of duck tape. and about half a roll of bailing wire..............It works great with my 2x4 lift kit
The time now is 06:18 PM.
