Snapped the head off the NSS module - JeepForum.com
post #1 of 15 Old 05-31-2013, 04:38 PM Thread Starter
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I was swapping out my NSS and I snapped the head off the only bolt holding it on. Any suggestions on how I can get the rest of the bolt out? It's a very tight spot and only about 1/4" of thread sticking out. Any help is appreciated.
For reference it's the red box
April 2014 & 2015 COTM
MOBBiN is offline
post #2 of 15 Old 05-31-2013, 10:34 PM
wgirvine
1992 XJ Cherokee
How to get the bolt out? With a reversible, 90-degree drill and a left-handed drill bit. Don't have one of those? Then you may have no choice but to drop the transmission.
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 15 Old 06-01-2013, 01:26 AM Thread Starter
MOBBiN
MOBBiN's Avatar
So far on the other forum I asked I've gotten the responses of: easy out or weld a nut on it. Ill see if an easy out works
MOBBiN is offline
post #4 of 15 Old 06-01-2013, 03:45 AM
sAe23
1995 XJ Cherokee
Good luck removing the broken bolt. Maybe dropping the exhaust will free up some space?
Be careful when prying the unit off that shaft. The "fingers" that the nut tightens up on can break off easily.
sAe23 is offline
post #5 of 15 Old 06-01-2013, 06:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you've got 1/4" sticking out, you've got something to grab or weld on to. I'm guessing you don't have a welder. The welding deal works well because not only do you get something to grip the broken piece, but the heat from welding the nut on usually releases the rust and crap binding the threaded piece into the aluminum.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 15 Old 06-01-2013, 12:31 PM
wgirvine
1992 XJ Cherokee
How are you going to drill the hole for the Easy-Out?
wgirvine is offline
post #7 of 15 Old 06-05-2013, 03:31 PM Thread Starter
MOBBiN
MOBBiN's Avatar
I went this route:
I used a 3.25" hole saw
There was yellow locktite on it
messed up a few threads so I drilled and tapped a bigger hole
MOBBiN is offline
post #8 of 15 Old 06-05-2013, 05:45 PM
sAe23
1995 XJ Cherokee
What is the metal plate you drilled a hole through??
sAe23 is offline
post #9 of 15 Old 06-05-2013, 07:45 PM Thread Starter
MOBBiN
MOBBiN's Avatar
The passengers side tranny tunnel.
MOBBiN is offline
post #10 of 15 Old 06-06-2013, 12:33 AM
sAe23
1995 XJ Cherokee
sAe23 is offline
post #11 of 15 Old 06-06-2013, 12:44 PM Thread Starter
MOBBiN
MOBBiN's Avatar
It's going to be patched, sealed then bed lined. Shouldn't be an issue
MOBBiN is offline
post #12 of 15 Old 06-06-2013, 02:35 PM
Jeep_Tech
wow guess you dont hit water much
Jeep_Tech is offline
post #13 of 15 Old 06-06-2013, 02:59 PM Thread Starter
MOBBiN
MOBBiN's Avatar
It's a large drain hole! Haha it'll be patched before I go threw anything deep.
MOBBiN is offline
post #14 of 15 Old 06-06-2013, 07:03 PM
sAe23
1995 XJ Cherokee
My icon-ic reply referred to Me not realizing the fact, not that you did it
sAe23 is offline
post #15 of 15 Old 06-06-2013, 08:23 PM Thread Starter
MOBBiN
MOBBiN's Avatar
Gotcha lol with the hole still being there its like having a second heater on full blast
MOBBiN is offline
