smoking ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > smoking ignition
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From Ruffstuff
Unread 08-01-2015, 04:32 PM   #1
snokedcheeze
Xj smoking ignition
So i went to start my 95 cherokee and noticed i ltte smoked so i turned if off and found that the red and violet wires were burnt. I cut it off where the black stopped and spliced on a new wire. After i hooked it all back up i connect the battery and it makes a ticking noise behind the dash that sounds like the turn signal. The dash lights also flash with the tick. Did i do something wrong?
snokedcheeze is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 04:38 PM   #2
snokedcheeze
heres the picture
