Quantcast Smoke From Steering Column? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Smoke From Steering Column?
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 12-24-2007, 03:05 PM   #1
Cherokeekid88
Well for the past week, ive smelled this weird smell inside the cab, i figured it was from where i dumped my exhaust but when i turn the heat on the smell goes away. Well today i got in my jeep and was driving down the road and saw ther was smoke coming from my steering column, not cloudy smoke but very vague smoke, any ideas?
97 XJ D30/29 Sp. 8.25. Yukon 4.10's
4.5" Lift With Custom Long Arms w/ Chomoly heims
IRO HD Tie Rod/IRO Adjustable Trac Bar
33x12.50x15 BFG AT's on 15x8 Soft 8's
Warn TC Skid/Full 2.5" Exhaust w/ Dynomax Bullet
Cherokeekid88 is offline   Reply With Quote
Old 12-24-2007, 03:57 PM   #2
red_01_xj
XJ Cherokee
check and see how your gromets are the ones that pass wires thought the fire wall...i noticed one of mine fell out of place
2000 RED XJ
4.5" RE Super Flex, Mono Tubes, 31" BFG AT, WJ seats Front and rear, Boxed Rocker panels with Rails, Upcountry Junkyard Special, homemade front bumper, C4x4 rear bumper and swing out, low profile light bar, jks disconects, farmboy tail lights lebaron hood vents, teraflex sye, Dana 30 HP with factory 4.56 disco converted to solid shafts, with powertrax, Dana 44 with detriot true trac with 4.56 and ZJ disc brakes...and the best part is all of my major mods are used
Ebay items http://motors.search.ebay.com/_W0QQsassZred01xj
red_01_xj is offline   Reply With Quote
Old 12-24-2007, 04:15 PM   #3
tangofox007
From my own experience and reports on this forum, it appears that this is the year for '88 model ignition switches to burn up.
tangofox007 is offline   Reply With Quote
Old 12-24-2007, 05:01 PM   #4
88XJSport
1988 XJ Cherokee
I will agree with tango. I smelled a burning smell, and changed my ignition switch and this is what I found. Since yours is an 88, it should look similar to mine.
88XJSport is offline   Reply With Quote
Old 12-24-2007, 06:57 PM   #5
tjwalker
It's the crank sensor!
tjwalker's Avatar
I agree with the above. Almost for sure the switch. You'll have to dig into the column to verify. I haven't seen it on an XJ but I have seen this exact problem on other vehicles. Time to dig in!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 12-24-2007, 10:02 PM   #6
Cherokeekid88
ok, so what all is involved with finding and replacing the ignition switch, and is it bad to drive it around with it like that?
Old 12-25-2007, 06:29 AM   #7
CharBroiled
just keep the fire extinguisher handy.
it can leave you stranded or cause other unpleasant thing to happen so you shouldnt ignore it.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling
[COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street
CharBroiled is offline   Reply With Quote
Old 12-25-2007, 07:15 AM   #8
Cherokeekid88
well i need to take it over to my buddies house so when can look at it, so would it be bad to drive it over there? or just get it towed?
Also what all is involved in this?
MERRY CHRISTMAS!
Old 12-25-2007, 07:37 AM   #9
CharBroiled
well, I would drive it over but thats just me. but you really need to get it fixed soonest.
Old 12-25-2007, 09:43 AM   #10
tangofox007
MERRY CHRISTMAS!
If it is the ignition switch, it is likely to eventually melt the track inside the switch, at which time you might not be able to turn the key. Mine caused some intermittent trouble before it finally became totally inoperative (and stuck in the "off" position.) So you can probably get away with driving it, but I would have a back-up plan so you don't get stranded.
The switch is not hard to replace, except for being difficult to access. You need to remove the bottom portion of the dash board. No need to remove or drop the steering column.
To avoid possible confusion, the switch in question is at the base of the steering column; it is not the lock cylinder.
Old 12-25-2007, 11:06 AM   #11
Cherokeekid88
ok cool. Well im gonna let betsy rest today and ill just have her towed over to my buddies house tomorrow. (AAA) and we will take a look at it. thanks for all your help guys. its funny though...last christmas eve, my alternator went out on the way BACK from my grandparents and this year my ignition switch burned up ON the way there.....
Old 12-25-2007, 01:19 PM   #12
REPOXP777
I had the same thing happen to me on my 89 . It melted in the same spot on the switch . Pretty easy to replace just a couple of nuts under the dash . Make sure to check to see how bad the wire connector is burned .
89 (RENIX) JEEP CHEROKEE 4.0 2WD SILVER
REPOXP777 is offline   Reply With Quote
Old 12-26-2007, 07:27 PM   #13
Cherokeekid88
ok just went out there and started taking the screws out to pull the lower dash. I think its 4 screws right below the steering column and then 2 screws on the bottom that holds down the yellow thing and then 1 screws that holds the bracket for the light that comes on when you open your doors at your feet, well i cant get one of the top screws out, i even used a drill but it wont catch it, so i looked up underneath it and i saw 2 bolts, maybe like a 10-14 mm bolt side by side and then i saw a bolt that is connected to a black rod that is diagonal and connected to something else, couldnt really see all that well. Am i getting close at all?? i couldnt really pinpoint where the actual ignition switch is at.
Glock Forum
