Smoke coming out of my steering column?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
I have a '93 Cherokee and I was driving home today when I noticed a little bit of smoke coming out of my steering column. I pulled over and checked out under the hood and everything, thinking maybe it was something else smoking and it was traveling up into the steering column and found nothing. I've sniffed it and it kind of smells like something eletrical. What the heck could be smoking and what can I do to fix it?
I live in Phoenix and it's been over 100 the past few days, could that have anything to do with it? Thanks for your help, I'm a bit worried about my jeep...
#2 |
your steering column in melting! park in the shade! wires shouldn't melt, fuses should blow! that's not a good sign. Try to chase down the smoke, if it's in the steering column, take it apart and try to see what s melting
2001 Cherokee Sport 4.0 L Selectrac (NV242), Automatic (AW4) Dana 30 Front, Chrysler 8.25 Rear RE 2.5" Add a Leafs, 2" Poly spacers, Bilstien Shocks = Vibes Class III hitch, Airlift Ride Control airbags Blue Ox Tow Plate with 2" front receiver, hitch shakle D-ring Yakima Roof Rack, JKS quicker disco's B&M Tranny Cooler, JCR Stage 2 Sliders Home brew rear bumpstop extenders 95 YJ extended brake lines, Speed Bleeders Revo 30x9.5 Gorilla locks |
#3 | |
#4 |
remove the upper and lower cover and all the wires are there.
My money is on the ignition switch. common thing in the summer with blower motor on high pulling amps thru it
89 XJ 4.0 auto 4x4 sway bars removed LT255/85r16 (33.5x9.5) BFG muds T/C ez ride 3.5 lift with BDS rear AAL MIG front locker Mopar Dealership parts Manager |
#5 |
Wow!!! It is going to look my Jeep. Former owner thought if the fuses kept blowing just use a bigger fuse!!
Hence all of my melted connectors on the interior. So you might have a nice big re-wire job like me!!!! But getting to the steering colum wires are easy to get to. just take off the lower panel that goes across the bottom and they should be visible.Mark
[B][FONT="Arial Black"][SIZE="2"]Black 1989 Limited 4.0L XJ Rough Country 3" AAL Pro Comp Xterain 31X10.50X15 Pro Comp 97 Series Rims "Martinez" Edition [/SIZE][/FONT][/B] |
#6 | |
#7 |
My '96 Cherokee did that about 2 years ago and nothing since then. Mine smelled electrical also. Freaked me out and I pulled over and yanked my stereo. Nothing quit working and everything has been fine since then. My friend had a similar experience in his Wrangler. Nothing failed so I can't help you.
2010 Liberty Renegade 2004 Nissan Titan Crew Cab LE |
#8 | |
#9 |
Man, if it was me, I'd strip out the entire dash until I found the burnt plastic or melted wiring. I can't afford for my jeep to go up in flames, especially since I park it in a garage that is directly beneath my bedroom.
#10 |
I'm also going to vote for the ignition switch. Mine did the same thing.
1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
#11 | |
#12 |
Ok, I've pulled apart the dash with no success, looking over everything, there's no char, nothing looks or feels melted. There's just alot of dust and even some cobwebs back in there. I did figure out the dash had been opened before, one screw on it didn't match the others. Hmm....
#13 |
my truck did that i think it was somthing with the turn signal it only did it 2 times once wen my dad drove it and once wen it became mine i dident see anything rong anny ware so i dunno must be a mopar mistery hmmm
92 Cherokee Trail toy. - 97 Cherokee Street toy. XJcruiser: Crumple zones? I guess the other car will have to share those. |
#14 |
Location: Suffield, CT (home), Point Judith, RI (school)
it sounds like your not in too bad of shape...
this kid that lived with me and his brother and another one of my firends and i went to wendys one night around midnight and right after we get our food and are headin back theres a wicked bad electrical smell and then billiowing smoke from the dash, we pulled into a bickfords parking lot (we were right next to it at the time) and ran in to see if we could get an extinguisher which the manager wouldnt give us(meinwhile the electrical fire is burning through wires under the dash setting off the lights the horn and even the starter at one point (my friend was holding the keys as we watched his smoking car crank from about 25 feet away) the police/fire department took a good 15 minutes to get there (from a station that was no more than 5 away). longer story short.... car was totaled... but his was shoddy wired interior neons from the previous owner that shorted out and caught fire, your case seems to be shared with others so hopefully its just one of the many mysteries that come with owning an xj
2000 XJ Sport, 4.0L, 4x4, NP231, Auto (wish it was 5-speed) All stock (for now, just wating for more cash) Pioneer Head (2) 12" Audiobahn 1200w Rockford Amp Alpine type-s all around "Jeep" Taillight first hopeful Upgrade... Spacers and Shackles -BIG plans!- |
#15 |
A perfect example is the above poster, and all of us. I cannot stress enough the importance of carrying a large, ABC rated fire extinguisher that can be reached from the driverseat at all time.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
