Slow Starting - JeepForum.com
post #1 of 9 Old 09-16-2003, 11:18 PM Thread Starter
JamieinNH
Slow Starting
My 1989 Cherokee will start everytime I have gotten in it, but when starting it it turns VERY slow. Is this just the nature of a Cherokee, or is there anything that can be done about it?
I did replace the battery with a new one when I got the Jeep.
Jamie
JamieinNH is offline
post #2 of 9 Old 09-16-2003, 11:42 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That seems to be a VERY common complaint for the older model cherokees. I don't recall ever really seeing a fix for it beyond replacing the CPS, but even then I couldn't say for sure that would cure it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 9 Old 09-17-2003, 11:24 AM
Apeman
Yes...it is a common problem with the 88-90 xj's with a Renix 4.0L engine...it is caused by a few things that the engineers didnt really think about...The computer will take an oil pressure reading to make sure there is sufficent pressure building up to allow the ngine to start without being "dry" (lack of oil). Thne it will read the CPS and fire up..during all of this the fuel pump will prime the fuel rail and ...Vroom..off you go...but the problem doesnt lie in the battery causing a slow crank..it lies in between the battery and your starter....the fricken wires are 8 guage for both the power and ground, and from the relay it is 18 guage...puny!!
I did a HD upgrade that cost me about $50.00 and it gets alot more power to the starter and all the other components in the system...if you want i can show you how to do it..and depending on how fancy you want your parts to be it can copst as little as $20.00....after the hour it took me to swap, there is no lag in starting, and no long crank times ( Although i have already swapped my fuel pump and CPS)
99XJ - Lifted and whatnot..oh, and its white.
Apeman is offline
post #4 of 9 Old 09-17-2003, 12:59 PM Thread Starter
JamieinNH
I would be interested in seeing how you fixed yours. Winter is just around the corner, and although I trust my Jeep to start, I always wonder in the back of my mind while it's turning over.
Thanks for any help you can offer!
Jamie
post #5 of 9 Old 09-17-2003, 01:25 PM
Apeman
Sure...PM me your e-mail address and i will send you some pics and instructions on what to do and what you need..it is really simple and should help.
Apeman is offline
post #6 of 9 Old 02-21-2013, 05:43 PM
WaaaghJunkie
Hey I was wondering if you still had this kicking around as I am having the same problem
WaaaghJunkie is offline
post #7 of 9 Old 02-21-2013, 07:55 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well, that was back in 2003.....
Go to the link below and check out the Renix tips. Ground refreshing #1 is in order for sure.
http://www.cherokeeforum.com/f51/cru...x-tips-153657/
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #8 of 9 Old 02-22-2013, 11:51 AM
WaaaghJunkie
Ya I was on my phone didnt check the date till later haha but thanks a lot, I did just throw a new battery in and was about to buy a brand new starter as well so ill just follow those steps
post #9 of 9 Old 02-22-2013, 12:58 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Dumba$$ smartphones!!. LOL.
Slow Starting MJ joedrives2fast MJ Comanche Technical Forum 9 03-13-2008 11:29 PM
Slow starting JGoad2 XJ Cherokee Technical Forum 6 05-06-2007 09:21 AM
Slow Starting cajunbull61 XJ Cherokee Technical Forum 9 03-10-2007 06:35 PM
slow starting jeeptorino68 XJ Cherokee Technical Forum 2 09-24-2006 11:17 AM
slow starting Jeep 89Cherokee XJ Cherokee Technical Forum 3 12-09-2002 02:25 PM
