Slow Start after long drive - JeepForum.com
post #1 of 2 Old 04-15-2010, 04:00 PM Thread Starter
duder123
1997 XJ Cherokee
So, I've recently had NSS troubles (i.e. no cranking, starting in neutral, reverse lights, etc...). I tried to clean it the other day, but could not get it off without possibly breaking it.
Around this same time (both before and after NSS attempt) I started noticing that occasionally, after driving for a while, I would get a slow start. It will crank fine, but I can't get it to fire up unless I really give it a lot of gas.
It never happens on a cold start though... only after I have driven it a bit, stopped, and then try to start back up. Seems more frequent on long trips.
should i start with the CPS? or Cam position sensor?
duder123 is offline
post #2 of 2 Old 04-16-2010, 11:08 AM
JBassXJ
JBassXJ's Avatar
I know a better internet mechanic will come through, but I'm thinkin that possibly the NSS is either just gettin' worse coupled with you may need to check the pressure at your fuel rail. Definitely get that NSS cleaned out and re-installed though.... I know their's a write-up on here somewhere...
soon to be enforced in close to all threads....
Originally Posted by Blake
Pics or ban.
JBassXJ is offline
cps , nss , slow start , won't start
slow to start damifinowfish XJ Cherokee Technical Forum 2 04-04-2010 06:49 PM
Slow Start jimbosz07 XJ Cherokee Technical Forum 4 03-19-2010 07:07 AM
Slow to Start rockntheXJ XJ Cherokee Technical Forum 13 09-21-2009 12:13 PM
Slow to start Dragasoni XJ Cherokee Technical Forum 10 10-14-2007 09:23 AM
Slow to start Dragasoni MJ Comanche Technical Forum 0 10-12-2007 11:36 AM
