Slip Yoke Lube? 97+ - JeepForum.com
post #1 of 5 Old 09-07-2008, 08:29 AM Thread Starter
Jeeptrek
Slip Yoke Lube? 97+
I have just one thing on my mind. I have read that people use Anti-Sezie for Lube on Slip Yoke(97+). Is this what I should use? Or should I get some Bel-Ray Grease?
Jeeptrek is offline
post #2 of 5 Old 09-07-2008, 09:01 AM
JeepRide
JeepRide's Avatar
I just did this to my jeep used wheel bearing grease it made the clunking noise go away.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #3 of 5 Old 09-07-2008, 10:38 AM
AZ Jeff
2014 JK Wrangler
Chrysler recommends a nicklel-bearing grease for that application. I would suspect that the version of Never-Sieze that has nickel in it would be a good substitute. You can get that at most decent auto parts stores (probably not at AutoZone, but certainly at NAPA.)
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 5 Old 09-07-2008, 10:43 AM
nujeepguy
1997 XJ Cherokee
i found that anti-seize was just not slippery e-nuf . it actually started clunking in a couple weeks. the only stuff that worked and lasted was lucas heavy duty grease. but any good chassis grease will work. lucas has been under there for over 15 months.
nujeepguy is offline
post #5 of 5 Old 09-07-2008, 07:55 PM Thread Starter
Jeeptrek
Thanks For the Help
Jeeptrek is offline
slip yoke lube 97tjtom XJ Cherokee Technical Forum 9 10-15-2012 04:14 PM
another name for the slip yoke? jeepdeez XJ Cherokee Technical Forum 1 06-29-2008 07:29 AM
How does this slip yoke come apart. 00xj54 XJ Cherokee Technical Forum 6 02-26-2007 06:33 PM
Slip Yoke? shierkahn XJ Cherokee Technical Forum 3 02-02-2007 10:29 AM
What grease should I get to slip my slip-yoke? Jeepokee XJ Cherokee Technical Forum 8 07-16-2006 12:41 PM
