Slip Yoke Eliminator - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Slip Yoke Eliminator
FREE Compressor With ARB Air Locker Purchase At FUELED 4WDQuality Products At The Prices You Want At FUELED 4WD!Quick Fist Clamps Now At FUELED 4WD!
Unread 07-04-2006, 11:31 PM   #1
OFFCHAMBERXJ
Ok I Am Putting A 6" On The Xj And I Know That I Need A Sye. Am I Going To Need A New Drive Shaft To Go Along With That. Or Can I Skip The Sye And Just Get A Cv Drive Shaft
OFFCHAMBERXJ is offline   Reply With Quote
Unread 07-04-2006, 11:43 PM   #2
Glazzed
you need the sye to install the cv drive shaft. this is what the new shaft looks like. notice how it connects at the transfer case. this if how your stock shaft looks like. see the difference?
1996, 4.0, AW4, Black XJ Sport, 6.5 Long arm, 4.88's and detroit locked at both ends, sitting on 35x12.50 ProComps
R.I.P. 1998, 4.0, AX15 5spd, White Cherokee Sport, 6.5 rusty's long arm, 33"x12.50 Baja Claw Radials. (sadly gone off to jeep heaven)
Glazzed is offline   Reply With Quote
Unread 07-04-2006, 11:57 PM   #3
OFFCHAMBERXJ
Thanks
That Is What Was Confusing Me "you Need Both"
WHEN IN DOUBT THROTTLE OUT. DO IT RIGHT THE FIRST TIME, OR PAY THE PRICE TO DO IT AGAIN AND AGAIN
Unread 07-05-2006, 02:21 AM   #4
youngwon22
The stock DS will pull out if you flex a lot or have a leaf warp, because it is basically just On the shaft of Transfer Case with a clamp, it'd be worse if you had 96 or older because it may cause leakage from the Transfer Case.
You get a hack-n-tap that bolts on to your TC shaft, then bolts on to the CV DS which obviously has better handling with greater angles (the angle of your DS and the TC due to that extra joint CV shafts have)
So with Hack-n-tap and the CV shaft, you can flex all you want w/o worrying about your driveshaft falling out, which increases the angle between the DS and TC, and the distance between your axle and the chasis.
I guess you could just do one or the other, but it probably won't satisfy you on a long run
youngwon22 is offline   Reply With Quote
Unread 07-05-2006, 12:32 PM   #5
conrasm
Yeah, You need a SYE to run the CV style driveshaft on you XJ. The stock setup is like many rear wheel drive vehicles...the rear driveshaft has a yoke that slips over the splined end of the transfer case output shaft. The older XJ's had an exterior seal that mated to the driveshaft...bad if you overflex and pull the driveshaft out b/c your fluid can leak out. The newer style incorporated a seal before the end of the output shaft so the driveshaft could be removed without all the fluid leaking out (see above pic).
My recommendations are:
If you have the newer XJ (97+) with the transfer case that is sealed and you are on a tight budget, then go with the hack 'n tap b/c it is cheaperr than a complete HD SYE (like advance adapters style). Although you will still need to get the adapter plate to use the front XJ driveshaft. It runs about $50 or so at NAPA.
If you have the pre-97 style, then I would suggest a complete HD SYE b/c it will be cheaper than than the hack n' tap for that style b/c the hack 'n tap is about the same price, plus you have to get the adapter plate, which puts it well beyond the price of the HD SYE.
I would go with the PORC (http://www.performanceoffroadcenter.com) SYE if you are looking for the heavy duty setup. It comes with a new main shaft for the TC and the install isn't that bad, although it may sound scary on paper.
My other question would be if you are getting a true 6" lift, as in, it will sit at 6" when on vehicle, or are you getting a lift that is advertised for 6" of lift, which means it could sit higher, which most lift do. If you think your end lift will be 6", then you could even use the front driveshaft from an XJ (which has a CV joint) and save yourelf some money over having a custom one made.
I have 6" of lift on my XJ from my 4.5" RE superflex kit and I installed the the PORC SYE and went to the junk yard and got a front DS from a late model XJ for $75 (some guys get them cheaper than that depending on your area) and did the whole thing for about $270 (after buying some tools, fluids, and RTV sealer.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Unread 07-05-2006, 02:31 PM   #6
Jeepin_XJ_101
It has to be from an Automatic XJ, remember that when you go boneyard diggin for one, they are only $10 at mine
"When in doubt... Floor it"
1989 XJ 4.0L I6 - AX-15 Swap - NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline   Reply With Quote
Unread 07-05-2006, 02:34 PM   #7
conrasm
And any year from 88+ will work. They were all the same from then on, so long as it's from a 4.0, AW4 auto.
$10!! Man, the bone yards around me and way too expensive. I couldn't find one for under $75, and they didn't give you a discount for older ones with more miles.
IMO, a total of 6" of lift is as high as I would go with the stock shaft. Any higher and I'd recommend a custom made one.
Shawn
Unread 07-05-2006, 03:45 PM   #8
youngwon22
and you have to have a C8.25 for it, D35 axles won't work with a front DS
Unread 07-05-2006, 03:53 PM   #9
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Yes they will. The pinion on a D35 is shorter than the 8.25", so the amount of lift that a front DS will work for might be slightly different, but a front DS will bolt right up to any factory rear axle on an XJ... D35, 8.25", or D44.
Jason West - Jeepin.com | JeepinOutfitters.com
'09 JKUR, RE 3.5", 37" GY MT/R-Ks, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Unread 07-17-2006, 07:18 PM   #10
OBXJ
Im about to install a Rustys 6.5" lift. Will this solution work for me and do you happen to have the adapter plate part number handy? Are there any drawbacks to using this method as opposed to spending the extra cash for the A/A unit?
2003 Jeep WJ Limited - Stock DD
1998 Jeep XJ - 4.0L, AX-15, Np231, Chrysler 8.25 rear, Dana 30 front, RE 4.5", 305/70R16 BFG MT's, 16" Cragar Soft 8's, OBA, Bushwacker Flares, AA SYE, CRC Custom DS, RE Gen2 Disco's, OME Nitro's, IPF H4 Headlights, Hella 500 Driving Lights, Factory Overhead Console, Surco/Yakima Roof rack, Hidden Hitch, K&N Apollo Intake, AirFlow Snorkel, AirRAID TBS, Alpine head unit with Sirius Module, sealed & hydroblocked.
OBXJ is offline   Reply With Quote
Unread 07-17-2006, 07:43 PM   #11
hmmhoyhoy
I am looking to get a 6 inch lift soon, what kind of steering upgrades are needed?
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline   Reply With Quote
Unread 07-19-2006, 03:00 PM   #12
OBXJ
Anyone have an answer to my question above?
Unread 03-23-2010, 12:23 AM   #13
Jeepedo
1997 XJ Cherokee
well i dono your feelings about cutting into your rear shaft, but ive been doin my research on this whole slip yoke eliminator and ive found a couple facts on both.
1 the Hack n' tap is cheaper but unless you know how to cut the rear shaft perfectly straight, drill a hole straight, and tap threads in it, you should probably steer clear of this way. b/c if you dont get these straight then you will get drive line vibes.
2 the hack n' tap, if done right, is just as strong and reliable as the sye kit.
For driveline choices, it differs from every jeep. depending on what type of pinion and lift you have is what will really decide if you can use a stock front xj drive line. if i remember right, correct me if im wrong, but 97-99 with c8.25 have high pinion and in 00-01 they went to low pinion. older years or newer years with ABS with the d35 have a high pinion as well.
but i found out that if the xj front drive line is too short for your jeep, than a zj front driveline is a little bit longer and will work for higher jeeps. personally i would go with the sye kit, to me they just sound better in the long run, and im not to good with cutting straight, Kindergarten teacher tried to explain it to me but i could never figure that one out.
so hopefully i helped with your decision making,
good luck
Jeepedo
If you like it rough, do it in a Jeep!
Eat, sleep, Jeep
Jeepedo is offline   Reply With Quote
Unread 03-23-2010, 07:35 AM   #14
Vendor
1995 XJ Cherokee
Holy old threads batman!
To clarify a few of the above statements, all XJs thru '99 have a HP D30 front end. All 00-01 have the LP D30. Both the D35 and 8.25" rear axles were used thru 2001, and while ABS guaranteed getting the D35, nothing guaranteed getting the 8.25" (I had an 01 with the D35).
The hack n tap kits are SYE kits, they're just not heavy duty sye kits like the short shaft kits from JB Conversions, Rugged Ridge, AA, etc.
Unread 03-23-2010, 07:36 AM   #15
Crewdude007
What, me worry?
That's some good advice. Keep in mind that you could also just measure the length you want and take it to a machine shop to have it cut and drilled for you. That would ensure that it was as straight as could be.
Another option is to buy a hack 'n tap kit from Tom Woods (I think). They send you the hack 'n tap pre-installed on a new rear output shaft. All you have to do is install it and send back your old one as a core charge.
Either of these options may /will add some expense, but this isn't something you want to screw up. Personally, I spent the money on an AA short shaft kit and I would definitely do it again.
2001 XJ - 7.5" RE front with 6.5" Rusty's rear springs
2000 WJ - Kolak Exhaust
Black Jeep Society
Built Not Bought
Crewdude007 is online now   Reply With Quote
